Differences
Link to this comparison view
user:poi:poi [29/07/2013 11:14]
alek
user:poi:poi [14/10/2013 17:42]
alek
Line 27: Line 27:
 In the first column of the table tick the places that should be seen on the map. To move to a created place, click on its name in the list. On the map, places can be displayed by their images and/or circles (depending on what is set in place properties) as well as their names. However, if the names are too long, you may want not to show them on the map. Disabling POI names is done in [[user/​set/​set#​unit_vizualization_on_map|user settings]] (remove the flag **Display POI names on the map**).  ​ In the first column of the table tick the places that should be seen on the map. To move to a created place, click on its name in the list. On the map, places can be displayed by their images and/or circles (depending on what is set in place properties) as well as their names. However, if the names are too long, you may want not to show them on the map. Disabling POI names is done in [[user/​set/​set#​unit_vizualization_on_map|user settings]] (remove the flag **Display POI names on the map**).  ​
-{{ :​map:​places03.png?​nolink }}
 Place a mouse cursor over a place name on the list or on the map to see related information in a tooltip: enlarged image, name, description,​ radius, and account name where the place belongs to (if there are several accounts). If the description contained any links to other images, they will be loaded and displayed, too. Example tooltip: ​ Place a mouse cursor over a place name on the list or on the map to see related information in a tooltip: enlarged image, name, description,​ radius, and account name where the place belongs to (if there are several accounts). If the description contained any links to other images, they will be loaded and displayed, too. Example tooltip: ​
Was this helpful?
Thank you!
