Differences
Link to this comparison view
user:monitor:groups [09/07/2013 19:14]
alek
user:monitor:groups [14/10/2013 17:39] (current)
alek
Line 28: Line 28:
   - Click on the button {{:​small:​command1.png?​nolink}} against the needed group. ​   - Click on the button {{:​small:​command1.png?​nolink}} against the needed group. ​
   - In the dialog there will be a list of units where those which support at least one command will be ticked. Select necessary units and press Next.    - In the dialog there will be a list of units where those which support at least one command will be ticked. Select necessary units and press Next.
-  - Select a command from the list of available commands. On the right you can choose the link type from the following: TCP, UDP, Virtual, SMS. Note that not all of these link types may be supported by your units. //Auto// means automatic choice of link type. \\ {{:small:command4.png?​nolink ​ }} A green sign against each command indicates that //all// of the selected units support the given command.\\ {{:small:command4a.png?​nolink ​ }} A yellow sign with the exclamation mark means that //not all// units support the command, and in the tooltip you can see the list of units which //do not support// it.\\ +  - Select a command from the list of available commands. On the right you can choose the link type from the following: TCP, UDP, Virtual, SMS. Note that not all of these link types may be supported by your units. //Auto// means automatic choice of link type. \\ {{:small:command3.png?​nolink ​ }} A green sign against each command indicates that //all// of the selected units support the given command.\\ {{:small:command3a.png?​nolink ​ }} A yellow sign with the exclamation mark means that //not all// units support the command, and in the tooltip you can see the list of units which //do not support// it.\\
   - Set additional parameters if needed. For example, input/​output index, report interval, etc. (depending on command type).   - Set additional parameters if needed. For example, input/​output index, report interval, etc. (depending on command type).
   - Press OK. The command will be executed immediately,​ and its result will be reported in the [[user/​gui/​log|log]]. ​   - Press OK. The command will be executed immediately,​ and its result will be reported in the [[user/​gui/​log|log]]. ​
