Differences
Link to this comparison view
Last revision Both sides next revision
user:monitor:groups [09/07/2013 19:14]
alek
alek
Line 16: Line 16:
 {{:​small:​gprs.png?​nolink}} connection state (connected/​not connected),​\\ ​ {{:​small:​gprs.png?​nolink}} connection state (connected/​not connected),​\\ ​
 {{:​small:​sensor_state.png?​nolink}} sensor state,\\ {{:​small:​sensor_state.png?​nolink}} sensor state,\\
-{{:small:configuration0.png?​nolink}} display group properties dialog,\\+{{:small:configuration.png?​nolink}} display group properties dialog,\\
 {{:​small:​command0.png?​nolink}} execute a command over a group of units,\\ {{:​small:​command0.png?​nolink}} execute a command over a group of units,\\
 {{:​small:​cross.png?​nolink}} remove a group form the list (but not form the system); if pressed at the head of the table, all groups are removed. ​ {{:​small:​cross.png?​nolink}} remove a group form the list (but not form the system); if pressed at the head of the table, all groups are removed. ​
Was this helpful?
Thank you!
