Both sides previous revision
Previous revision
Next revision
Previous revision
user:mobile:mobile [12/07/2011 10:41] alek |
user:mobile:mobile [29/03/2013 12:28] (current) |
| {{indexmenu_n>41}} |
====== Wialon Mobile ====== | ====== Wialon Mobile ====== |
To access the mobile site, enter address in the browser. On the first page, enter your user name and access key as it is set in [[user/set/general|User Settings]]. You can also select the interface language. When logged in, observe the main menu and select the operation to perform. | To access the mobile site, enter address in the browser. On the first page, enter your user name and access key as it is set in [[user/set/general|User Settings]]. You can also select the interface language. When logged in, observe the main menu and select the operation to perform. |
{{ :mobile:mobile01.png }} | {{ :mobile:mobile01.png?nolink }} |
===== Unit Information ===== | ===== Unit Information ===== |
Select unit to get information about, push Next and get the data. The information includes unit name and device type, its location and speed, time when the latest message was received. It also provides all sensors values, the latest event, and phone number if available. | Select unit to get information about, push Next and get the data. The information includes unit name and device type, its location and speed, time when the latest message was received. It also provides all sensors values, the latest event, and phone number if available. |
{{ :mobile:mobile02.png }} | {{ :mobile:mobile02.png?nolink }} |
When a time passed, you can get fresher information about the unit. Simply push the Refresh button to get the latest data. | When a time passed, you can get fresher information about the unit. Simply push the Refresh button to get the latest data. |
Select one or more units to monitor them and click Next. Select time interval to map the track for, indicate map size and scale. Push Show to display the search result. | Select one or more units to monitor them and click Next. Select time interval to map the track for, indicate map size and scale. Push Show to display the search result. |
{{ :mobile:mobile03.png }} | {{ :mobile:mobile03.png?nolink }} |
The map can be moved and zoomed using the appropriate buttons above (arrows - to move, plus and minus - to zoom). However, if more than one unit is selected, then the map is scaled in such a way to show all units, and it is impossible to move and zoom it. | The map can be moved and zoomed using the appropriate buttons above (arrows - to move, plus and minus - to zoom). However, if more than one unit is selected, then the map is scaled in such a way to show all units, and it is impossible to move and zoom it. |
Select one or more units to execute a command. In the next window choose the command, if this is a custom message or a message for the driver, enter message text. At the end click the Send button. You will be notified whether the action was successful. | Select one or more units to execute a command. In the next window choose the command, if this is a custom message or a message for the driver, enter message text. At the end click the Send button. You will be notified whether the action was successful. |
{{ :mobile:mobile04.png }} | {{ :mobile:mobile04.png?nolink }} |
===== Search ===== | ===== Search ===== |
To find a place on the map, enter some first characters of the city and/or street, add house number if you need more accurate search. Set also map size and scale. The received result you can scale and move. | To find a place on the map, enter some first characters of the city and/or street, add house number if you need more accurate search. Set also map size and scale. The received result you can scale and move. |
{{ :mobile:mobile05.png }} | {{ :mobile:mobile05.png?nolink }} |
