Differences
Link to this comparison view
Next revision
Previous revision
manager:units:sensors:start [14/10/2013 16:31]
alek
manager:units:sensors:start [26/11/2013 18:09]
alek
Line 14: Line 14:
 To delete a sensor, select this sensor and press //Delete Sensor//​. ​ To delete a sensor, select this sensor and press //Delete Sensor//​. ​
-{{ :​units:​unit05.png?​nolink }}+{{ :​units:​unit05.png?​nolink }}
 If you use similar devices for different units, it is convenient to configure sensors once, and then [[manager/​units/​imp-exp|import]] them to other units. ​ If you use similar devices for different units, it is convenient to configure sensors once, and then [[manager/​units/​imp-exp|import]] them to other units. ​
Line 28: Line 28:
 **Sensor type**\\ Choose the [[manager/​units/​sensors/​types|sensor]] type form the dropdown list of available types. ​ **Sensor type**\\ Choose the [[manager/​units/​sensors/​types|sensor]] type form the dropdown list of available types. ​
-**Unit of measure**\\ As a rule, possible unit of measure is given. However you can key in your own.  This is especially applicable for digital sensors such as engine ​operation ​sensor or custom digital sensors. Instead of default On/Off values you can key in //​Activated/​Deactivated//,​ //​Laden/​Unladen//,​ and the like.+**Unit of measure**\\ As a rule, possible unit of measure is given. However you can key in your own.  This is especially applicable for digital sensors such as engine ​ignition ​sensor or custom digital sensors. Instead of default On/Off values you can key in //​Activated/​Deactivated//,​ //​Laden/​Unladen//,​ and the like.
 **Parameter**\\ [[manager/​units/​sensors/​parameter|Parameters]] come in messages. If the unit already has messages, parameter name can be picked up from the list of available in the last message. ​ **Parameter**\\ [[manager/​units/​sensors/​parameter|Parameters]] come in messages. If the unit already has messages, parameter name can be picked up from the list of available in the last message. ​
