Differences
Link to this comparison view
Last revision Both sides next revision
manager:units:sensors:start [14/10/2013 16:31]
alek
manager:units:sensors:start [15/11/2013 18:25]
alek
Line 14: Line 14:
 To delete a sensor, select this sensor and press //Delete Sensor//​. ​ To delete a sensor, select this sensor and press //Delete Sensor//​. ​
-{{ :​units:​unit05.png?​nolink }}+{{ :​units:​unit05.png?​nolink }}
 If you use similar devices for different units, it is convenient to configure sensors once, and then [[manager/​units/​imp-exp|import]] them to other units. ​ If you use similar devices for different units, it is convenient to configure sensors once, and then [[manager/​units/​imp-exp|import]] them to other units. ​
Was this helpful?
Thank you!
