Differences
Link to this comparison view
Next revision
Previous revision
manager:units:sensors:parameter [10/09/2013 15:07]
alek
manager:units:sensors:parameter [14/10/2013 16:33]
alek
Line 28: Line 28:
 ^**adc**N| analog input parameter, ​ N - input number| ^**adc**N| analog input parameter, ​ N - input number|
-For example, //adc8// is referred to as parameter which registers the values coming ​form the eighth analog input. ​+For example, //adc8// is referred to as parameter which registers the values coming ​from the eighth analog input. ​
 Normally, data from digital inputs and outputs are presented in messages in the following format: I/O = 0/0, where I refers to inputs, O - outputs. If I/O = 0/0, it means all bits (inputs and outputs) are inactive. If something of them is not zero, it means that an input/​output or several of them are active. To define, which of them exactly, hexadecimal number (which you see in message) must be converted into bit number. ​ Normally, data from digital inputs and outputs are presented in messages in the following format: I/O = 0/0, where I refers to inputs, O - outputs. If I/O = 0/0, it means all bits (inputs and outputs) are inactive. If something of them is not zero, it means that an input/​output or several of them are active. To define, which of them exactly, hexadecimal number (which you see in message) must be converted into bit number. ​
Line 46: Line 46:
 Besides, **constN** parameter can be used to create a sensor which always returns the same value. N is any number, e.g. const10, const-8.5. Such a sensor can be helpful in charts or as a validator. ​ Besides, **constN** parameter can be used to create a sensor which always returns the same value. N is any number, e.g. const10, const-8.5. Such a sensor can be helpful in charts or as a validator. ​
-Such a sensor can be used both independently (for example, in charts to mark some critical line) or as a part of [[manager/​units/​validation|validation]] chain or in [[#​expressions|expressions]]. ​+Such a sensor can be used both independently (for example, in charts to mark some critical line) or as a part of [[manager/​units/sensors/​validation|validation]] chain or in [[#​expressions|expressions]]. ​
 ===== Expressions ===== ===== Expressions =====
