Differences
Link to this comparison view
manager:units:imp-exp [29/03/2013 12:28]
127.0.0.1 external edit
manager:units:imp-exp [10/04/2013 11:31] (current)
alek
Line 23: Line 23:
 Settings previously saved to an XML file can be imported to a unit. To do this, in the import/​export menu select the option **Import from file**, choose a file on the disk, check needed settings and press OK. The result will be shown right in the dialog: ​ Settings previously saved to an XML file can be imported to a unit. To do this, in the import/​export menu select the option **Import from file**, choose a file on the disk, check needed settings and press OK. The result will be shown right in the dialog: ​
-  * "​ОК"​ - the section has been imported successfully;​ +  * "​ОК" ​-- the section has been imported successfully;​
-  * "​Missing"​ - the source file does not contain such section at all, so this section in the destination file will remain untouched;​ +  * "​Missing" ​-- the source file does not contain such section at all, so this section in the destination file will remain untouched;​
-  * "​Error"​ - this section cannot be imported because of some file error. ​+  * "​Error" ​-- this section cannot be imported because of some file error. ​
 {{ :​units:​import.png?​nolink }} {{ :​units:​import.png?​nolink }}
