Differences
Link to this comparison view
manager:units:fuel [14/10/2013 16:37]
alek
manager:units:fuel [14/10/2013 16:37] (current)
alek
Line 14: Line 14:
 **Minimum fuel theft volume**: how considerable should be fuel level fall to be  regarded as a discharge. This is activated only when the unit is stationary. ​ **Minimum fuel theft volume**: how considerable should be fuel level fall to be  regarded as a discharge. This is activated only when the unit is stationary. ​
-**Ignore the messages after the start of motion, sec**. At the very beginning of movement the data on fuel level can not accurate, so you can ignore these messages. ​+**Ignore the messages after the start of motion, sec**. At the very beginning of movement the data on fuel level can be not accurate, so you can ignore these messages. ​
 **Minimum stay timeout to detect fuel theft, sec**: how long should continue a stay accompanied with fuel level decreasing to be regarded as fuel theft. ​ **Minimum stay timeout to detect fuel theft, sec**: how long should continue a stay accompanied with fuel level decreasing to be regarded as fuel theft. ​
