Differences
Link to this comparison view
Last revision Both sides next revision
manager:rights:start [04/04/2013 13:15]
alek
alek
Line 66: Line 66:
 Open user configuration dialog and go to the //Access to objects// tab. On the left there is the objects tree (units, unit groups, users, accounts), on the right there are several radio buttons which represent different access levels. In the objects tree select needed objects and assign the access to them using radio buttons on the right. In accordance with rights assigned, items acquire a background of the corresponding color. To save changes, push OK.  Open user configuration dialog and go to the //Access to objects// tab. On the left there is the objects tree (units, unit groups, users, accounts), on the right there are several radio buttons which represent different access levels. In the objects tree select needed objects and assign the access to them using radio buttons on the right. In accordance with rights assigned, items acquire a background of the corresponding color. To save changes, push OK.
-{{ :dialogs:​users03.png?​nolink }}+{{ :users:​users03.png?​nolink }}
 :!: //​Hint//​.\\ ​ :!: //​Hint//​.\\ ​
Was this helpful?
Thank you!
