Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
manager:rights:start [29/03/2013 12:28]
127.0.0.1 external edit
manager:rights:start [04/04/2013 13:15]
alek
Line 66: Line 66:
 Open user configuration dialog and go to the //Access to objects// tab. On the left there is the objects tree (units, unit groups, users, accounts), on the right there are several radio buttons which represent different access levels. In the objects tree select needed objects and assign the access to them using radio buttons on the right. In accordance with rights assigned, items acquire a background of the corresponding color. To save changes, push OK.  Open user configuration dialog and go to the //Access to objects// tab. On the left there is the objects tree (units, unit groups, users, accounts), on the right there are several radio buttons which represent different access levels. In the objects tree select needed objects and assign the access to them using radio buttons on the right. In accordance with rights assigned, items acquire a background of the corresponding color. To save changes, push OK.
-{{ :dialogs:​users03.png?​nolink ​|Assigning access rights for a users to objects}}+{{ :users:​users03.png?​nolink }}
 :!: //​Hint//​.\\ ​ :!: //​Hint//​.\\ ​
Line 78: Line 78:
 Open unit properties dialog and move to the **Access for users** tab. On the left there is a list of all users available. On the right you assign for them access level to the unit. Here <​ctrl>​ and <​shift>​ keys are used in the same way.  Open unit properties dialog and move to the **Access for users** tab. On the left there is a list of all users available. On the right you assign for them access level to the unit. Here <​ctrl>​ and <​shift>​ keys are used in the same way.
-{{ :​units:​unit02.png?​nolink ​|Assigning access rights to a unit}}+{{ :​units:​unit02.png?​nolink }}
 **Through Unit Group Properties** **Through Unit Group Properties**
 In a similar way access rights on unit groups are assigned. When creating, updating or copying a group, move to the **Accessors** tab. Remember that rights assigned here are applied to each ans every unit in the group. Here you can increase rights only and not vice versa. ​ In a similar way access rights on unit groups are assigned. When creating, updating or copying a group, move to the **Accessors** tab. Remember that rights assigned here are applied to each ans every unit in the group. Here you can increase rights only and not vice versa. ​
Was this helpful?
Thank you!
