Differences
Link to this comparison view
Last revision Both sides next revision
admin:variables:storage [29/03/2013 12:28]
127.0.0.1 external edit
admin:variables:storage [18/04/2013 18:55]
alek
Line 4: Line 4:
 Storage system configuration (except online backup) is managed in a special configuration file. This file is //not// created automatically while installing or starting Wialon, so default parameters are taken. If any corrections of storage system parameters are required, it is recommended to redefine only those variables which should be altered. ​ Storage system configuration (except online backup) is managed in a special configuration file. This file is //not// created automatically while installing or starting Wialon, so default parameters are taken. If any corrections of storage system parameters are required, it is recommended to redefine only those variables which should be altered. ​
-The path to the file: storage/​storage.cfg+The path to the file: custom/​storage.cfg
 Here is an example of a configuration file with default parameters and their description: ​ Here is an example of a configuration file with default parameters and their description: ​
