Differences
Link to this comparison view
admin:variables:maps [24/12/2014 14:50]
daev
admin:variables:maps [19/01/2015 13:30] (current)
daev
Line 14: Line 14:
 ^  Variable ​ ^  Description ​ | ^  Variable ​ ^  Description ​ |
 | WIALON_WEB_DEFAULT_POS |Set the default map position and zoom when the monitoring site is opened. Enter latitude, longitude, and zoom level, separating them by colon (for example, WIALON_WEB_DEFAULT_POS = 55.739162:​49.199269:​9). | | WIALON_WEB_DEFAULT_POS |Set the default map position and zoom when the monitoring site is opened. Enter latitude, longitude, and zoom level, separating them by colon (for example, WIALON_WEB_DEFAULT_POS = 55.739162:​49.199269:​9). |
 +| WIALON_WEB_GOOGLE_CLIENT |Google Maps paid key. |
 | WIALON_WEB_WEBGIS_COPYRIGHT| If you use your own WebGIS maps, enter copyright text for them here. See [[admin/​maps/​start|]] to learn how to create maps. | | WIALON_WEB_WEBGIS_COPYRIGHT| If you use your own WebGIS maps, enter copyright text for them here. See [[admin/​maps/​start|]] to learn how to create maps. |
 | WIALON_WEB_YANDEX_KEYS |Keys to activate **Yandex Maps** for different URLs. To use these maps, [[http://​api.yandex.ru/​maps/​form.xml|get the key]]. How to set the value for this variable is described below.| | WIALON_WEB_YANDEX_KEYS |Keys to activate **Yandex Maps** for different URLs. To use these maps, [[http://​api.yandex.ru/​maps/​form.xml|get the key]]. How to set the value for this variable is described below.|
