Differences
Link to this comparison view
Last revision Both sides next revision
admin:variables:general [29/03/2013 12:28]
127.0.0.1 external edit
admin:variables:general [07/10/2013 11:42]
alek
Line 14: Line 14:
 | WIALON_DISKSPACE_EMAIL_TO | Destination e-mail to send a warning about insufficient disk space. | | WIALON_DISKSPACE_EMAIL_TO | Destination e-mail to send a warning about insufficient disk space. |
 | ADF_SMTP_SERVER |SMTP server address is set in the form <​host>:<​port>​. This server is used to send messages from software. By default, the local computer and the port 25 are used.\\ :!: SMTP server must maintain the operation without authentication from monitoring server IP address.| | ADF_SMTP_SERVER |SMTP server address is set in the form <​host>:<​port>​. This server is used to send messages from software. By default, the local computer and the port 25 are used.\\ :!: SMTP server must maintain the operation without authentication from monitoring server IP address.|
-| ADF_STORAGE_NET_SERVER | //For Wialon [[admin/​client/​start|]] only//. Set the port and network interface address to listen connections by the form <​port>:<​IP address>​. IP address can be skiped ​to listen on all local network interfaces. Default port is 31188. :!: To initialize server part in the trusted mode to any connected user (that is the authorization is not required), the third parameter set as '​1'​ is needed, for example, '​31188:​*:​1'​. |+| ADF_STORAGE_NET_SERVER | //For Wialon [[admin/​client/​start|]] only//. Set the port and network interface address to listen connections by the form <​port>:<​IP address>​. IP address can be skipped ​to listen on all local network interfaces. Default port is 31188. :!: To initialize server part in the trusted mode to any connected user (that is the authorization is not required), the third parameter set as '​1'​ is needed, for example, '​31188:​*:​1'​. |
 | ADF_STORAGE_NET_REMOTE_SERVER | //For Wialon [[admin/​client/​start|]] only//. Set the port and network interface address where Wialon Pro is located (main database). The format is: <​port>:<​IP address>​. Default port is 31188. ​ | | ADF_STORAGE_NET_REMOTE_SERVER | //For Wialon [[admin/​client/​start|]] only//. Set the port and network interface address where Wialon Pro is located (main database). The format is: <​port>:<​IP address>​. Default port is 31188. ​ |
 | ADF_STORAGE_PROTECTED_PROP_READING | Protected reading of objects'​ properties: 1 -- on, 0 -- off. | | ADF_STORAGE_PROTECTED_PROP_READING | Protected reading of objects'​ properties: 1 -- on, 0 -- off. |
Was this helpful?
Thank you!
