Differences
Link to this comparison view
admin:upgrade:version [27/12/2013 15:41]
alek
admin:upgrade:version [17/12/2019 12:05] (current)
mary [Installing Upgrades] olya
Line 18: Line 18:
 ===== Installing Upgrades ===== ===== Installing Upgrades =====
-  - Download the newest distribution of Wialon Pro 1301 from [[https://distro.gurtam.com|Gurtam Distro Area]] and unzip it.+  - Download the newest distribution of Wialon Pro 1301 from the [[https://my.gurtam.com/en/login|personal account]] and unzip it.
   - Stop the current Wialon Pro 1101 or 1006 process, clean //tmp// directory, and make backups of all other directories. ​   - Stop the current Wialon Pro 1101 or 1006 process, clean //tmp// directory, and make backups of all other directories. ​
   - Install the new distribution on top of the existing one. If you have purchased new functional modules, you may need to configure them in the file //​custom/​config.txt//​ according to [[admin/​variables/​start|variables described above]]. As a way to identify these variables, you can answer //yes// to the question //Install custom configuration (folder)// and then view in your new //​custom/​config.txt//​ all new variables. In this case, be careful and do not forget to recover //custom directory// before the first start. ​   - Install the new distribution on top of the existing one. If you have purchased new functional modules, you may need to configure them in the file //​custom/​config.txt//​ according to [[admin/​variables/​start|variables described above]]. As a way to identify these variables, you can answer //yes// to the question //Install custom configuration (folder)// and then view in your new //​custom/​config.txt//​ all new variables. In this case, be careful and do not forget to recover //custom directory// before the first start. ​
