Differences
Link to this comparison view
Last revision Both sides next revision
admin:upgrade:version [07/10/2013 15:22]
alek
admin:upgrade:version [27/12/2013 15:41]
alek
Line 13: Line 13:
   * Wialon Pro 1301 can be installed only on Linux-based operation systems, the 2.6 kernel, and 64-bit architecture (x86_64).   * Wialon Pro 1301 can be installed only on Linux-based operation systems, the 2.6 kernel, and 64-bit architecture (x86_64).
   * Backup system is available only in the form of [[admin/​reserve/​server|separate backup server]] that is a paid module. We strongly recommend to purchase this module to protect your tracking system from any hardware and software failures.   * Backup system is available only in the form of [[admin/​reserve/​server|separate backup server]] that is a paid module. We strongly recommend to purchase this module to protect your tracking system from any hardware and software failures.
-  * Message database has to be upgraded from the format v1 to the format v2. Depending on database size, it can take from a couple of minutes to several days. The upgrade can be performed in the 'hot mode', that is while Wialon is working. Database upgrade is strongly recommended because an old database in the format v1 cannot be synchronized to the backup server and cannot participate in various optimization processes. ​+  * Message database has to be upgraded from the format v1 to the format v2. Depending on database size, it can take from a couple of minutes to several days. The upgrade can be performed in the 'hot mode', that is while Wialon is working. Database upgrade is strongly recommended because an old database in the format v1 cannot be synchronized to the backup server and cannot participate in various optimization processes
 +  * Interface of the monitoring site has changed dramatically,​ so your personal designs should be reviewed and accorded to the new layout
 ===== Installing Upgrades ===== ===== Installing Upgrades =====
