Differences
Link to this comparison view
Next revision
Previous revision
admin:upgrade:start [03/04/2013 12:42]
alek
admin:upgrade:start [07/10/2013 15:19]
alek
Line 2: Line 2:
 ====== Upgrading Distribution ====== ====== Upgrading Distribution ======
-Installation of distribution of Wialon Pro 1306 is similar to [[admin:​install:​|]]. When installing on top of another version of Wialon Pro, installation script by default does not overwrite //custom// directory that contains all your local settings. ​+Installation of distribution of Wialon Pro 1301 is similar to [[admin:​install:​|]]. When installing on top of another version of Wialon Pro, installation script by default does not overwrite //custom// directory that contains all your local settings. ​
-It is strongly recommended to make a backup copy of two directories - //custom// (your settings) and //storage// (database). Backup is made while Wialon Pro is stopped. ​+It is strongly recommended to make a backup copy of two directories ​-- //custom// (your settings) and //storage// (database). Backup is made while Wialon Pro is stopped. ​
-Two ways to apgrade ​Wialon Pro are possible: ​+Two ways to upgrade ​Wialon Pro are possible: ​
-  * [[modules|Installing Wialon Pro 1306 with new modules and functionality]];​ +  * [[modules|Installing Wialon Pro 1301 with new modules and functionality]];​
-  * [[version|Installing Wialon Pro 1306 on top of Wialon Pro 1101 or Wialon Pro 1006]].+  * [[version|Installing Wialon Pro 1301 on top of Wialon Pro 1101 or Wialon Pro 1006]].
 See also:  See also:
-  * [[releases|All ​versions ​of Wialon Pro 1301]].+  * [[releases|All ​releases ​of Wialon Pro 1301]].
