Differences
Link to this comparison view
Next revision
Previous revision
admin:reserve:backup [09/09/2011 14:59]
alek
admin:reserve:backup [07/10/2013 15:27] (current)
alek
Line 2: Line 2:
 ====== Backup with LVM ====== ====== Backup with LVM ======
-Backup system in Wialon Pro 1106 can be organized on the basis of [[http://​en.wikipedia.org/​wiki/​Logical_Volume_Manager_%28Linux%29|LVM]] (Logical Volume Manager). ​+Backup system in Wialon Pro 1301 can be organized on the basis of [[http://​en.wikipedia.org/​wiki/​Logical_Volume_Manager_%28Linux%29|LVM]] (Logical Volume Manager). ​
 Perform the following actions to set up the backup system by yourself: ​ Perform the following actions to set up the backup system by yourself: ​
Line 182: Line 182:
 # lvcreate -L1G -s -n storage_snap /​dev/​berkleydb/​storage ​ # lvcreate -L1G -s -n storage_snap /​dev/​berkleydb/​storage ​
 </​code>​ </​code>​
-From this moment you have a backup copy of your database. ​+
 +From this momentyou have a backup copy of your database. ​
 It is recommended to save the snapshot on a disk or to a file using the command //dd// (to make sure, store it on three mediums). Then in case of fall, you could mount this snapshot or restore the original. ​ It is recommended to save the snapshot on a disk or to a file using the command //dd// (to make sure, store it on three mediums). Then in case of fall, you could mount this snapshot or restore the original. ​
 To automate the backup procedure, you can write a script and start it according on schedule using //​cron//​. ​ To automate the backup procedure, you can write a script and start it according on schedule using //​cron//​. ​
Was this helpful?
Thank you!
