Differences
Link to this comparison view
admin:reserve:backup [03/04/2013 12:43]
alek
admin:reserve:backup [07/10/2013 15:27]
alek
Line 182: Line 182:
 # lvcreate -L1G -s -n storage_snap /​dev/​berkleydb/​storage ​ # lvcreate -L1G -s -n storage_snap /​dev/​berkleydb/​storage ​
 </​code>​ </​code>​
-From this moment you have a backup copy of your database. ​+
 +From this momentyou have a backup copy of your database. ​
 It is recommended to save the snapshot on a disk or to a file using the command //dd// (to make sure, store it on three mediums). Then in case of fall, you could mount this snapshot or restore the original. ​ It is recommended to save the snapshot on a disk or to a file using the command //dd// (to make sure, store it on three mediums). Then in case of fall, you could mount this snapshot or restore the original. ​
 To automate the backup procedure, you can write a script and start it according on schedule using //​cron//​. ​ To automate the backup procedure, you can write a script and start it according on schedule using //​cron//​. ​
