Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
admin:reserve:backup [15/08/2011 11:10]
alek
admin:reserve:backup [03/04/2013 12:43]
alek
Line 2: Line 2:
 ====== Backup with LVM ====== ====== Backup with LVM ======
-Backup system in Wialon Pro 1106 can be organized on the basis of [[http://​en.wikipedia.org/​wiki/​Logical_Volume_Manager_%28Linux%29|LVM]] (Logical Volume Manager). ​+Backup system in Wialon Pro 1301 can be organized on the basis of [[http://​en.wikipedia.org/​wiki/​Logical_Volume_Manager_%28Linux%29|LVM]] (Logical Volume Manager). ​
 Perform the following actions to set up the backup system by yourself: ​ Perform the following actions to set up the backup system by yourself: ​
Line 8: Line 8:
   - Install and set up LVM.    - Install and set up LVM.
   - Move your database to LVM.    - Move your database to LVM.
-  - Set up FSTAB. ​+  - Set up [[http://​en.wikipedia.org/​wiki/​Fstab|FSTAB]]
   - Do the checkup. ​   - Do the checkup. ​
Line 119: Line 119:
 </​code> ​ </​code> ​
-===== 2. Перенос базы данных на LVM =====+===== 2. Transfer Database to LVM =====
 Format the logical partition //storage// (in the example below //xfs// file system is used): ​ Format the logical partition //storage// (in the example below //xfs// file system is used): ​
Was this helpful?
Thank you!
