Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
admin:reserve:backup [15/08/2011 11:10]
alek
admin:reserve:backup [09/09/2011 14:59]
alek
Line 8: Line 8:
   - Install and set up LVM.    - Install and set up LVM.
   - Move your database to LVM.    - Move your database to LVM.
-  - Set up FSTAB. ​+  - Set up [[http://​en.wikipedia.org/​wiki/​Fstab|FSTAB]]
   - Do the checkup. ​   - Do the checkup. ​
Line 119: Line 119:
 </​code> ​ </​code> ​
-===== 2. Перенос базы данных на LVM =====+===== 2. Transfer Database to LVM =====
 Format the logical partition //storage// (in the example below //xfs// file system is used): ​ Format the logical partition //storage// (in the example below //xfs// file system is used): ​
Was this helpful?
Thank you!
