Differences
Link to this comparison view
Next revision
Previous revision
admin:admin:user_groups [05/07/2011 11:32]
alek
admin:admin:user_groups [07/10/2013 11:48]
alek
Line 4: Line 4:
 Two groups are created by default while installing the service - **Administrators** and **All Users**. They cannot be deleted. All newly created users are added to //All Users// group automatically. ​ Two groups are created by default while installing the service - **Administrators** and **All Users**. They cannot be deleted. All newly created users are added to //All Users// group automatically. ​
-{{  :​admin:​user_groups.png  ​|User Groups}}+{{  :​admin:​user_groups.png?​nolink ​ }}
 To create a new group, press **Create User Group** button. ​ To create a new group, press **Create User Group** button. ​
-{{  :​admin:​create_user_group.png  ​|User group properties}}+{{  :​admin:​create_user_group.png?​nolink ​ }}
 Enter a name for the group and select users to form it (add users from the left column to the right). Then press OK button. ​ Enter a name for the group and select users to form it (add users from the left column to the right). Then press OK button. ​
Line 16: Line 16:
 To delete a group, press the **delete** button against its name. Deleting a group does not mean deleting users which belongs to this group. ​ To delete a group, press the **delete** button against its name. Deleting a group does not mean deleting users which belongs to this group. ​
-Access right to user group are assigned in the same way as for separate users. See [[admin/​admin/​users#​access_management|Access Management]] for details. If a right is assigned to a group, it means that it is applied to all abjects ​which belong to this group. However, if higher access was given earlier to a certain user, this high level will be preserved. ​+Access right to user group are assigned in the same way as for separate users. See [[admin/​admin/​users#​access_management|Access Management]] for details. If a right is assigned to a group, it means that it is applied to all objects ​which belong to this group. However, if higher access was given earlier to a certain user, this high level will be preserved. ​
 :!: //​ATTENTION//​!\\ When editing groups never delete yourself from the group of administrators because you will lose the right to enter admin site.  :!: //​ATTENTION//​!\\ When editing groups never delete yourself from the group of administrators because you will lose the right to enter admin site.
