Differences
Link to this comparison view
Next revision
Previous revision
admin:admin:modems [29/03/2013 12:28]
127.0.0.1 external edit
admin:admin:modems [07/10/2013 11:53]
alek
Line 16: Line 16:
 ==== General ==== ==== General ====
-{{  :​admin:​modems1.png?​nolink  ​|Modem Properties Dialog}}+{{  :​admin:​modems1.png?​nolink ​ }}
   * **Name**: enter a name for the modem. ​   * **Name**: enter a name for the modem. ​
Line 65: Line 65:
 By default, SMS messages are transmitted with UDH method (User Data Header) where system information is placed at the beginning. SAR method (segmentation and reassembly) allows to place this information at the end in TLV format which is essential for several languages that se characters which cannot be transmitted in 8-bit encoding. In these cases the option **Split long SMS using SAR method** can be used to solve the problem. ​ By default, SMS messages are transmitted with UDH method (User Data Header) where system information is placed at the beginning. SAR method (segmentation and reassembly) allows to place this information at the end in TLV format which is essential for several languages that se characters which cannot be transmitted in 8-bit encoding. In these cases the option **Split long SMS using SAR method** can be used to solve the problem. ​
 +Check the option **Remove '​+'​ in destination number** to eliminate the plus symbol from destination phone numbers.  ​
 Check **Use 8-bit encoding only** if needed. Check **Use 8-bit encoding only** if needed.
 +Enter **Ton/Npi** in indicated format if necessary. ​
 In addition, you can set the variable **ADF_SERIAL_SMPP_SRC_ADDR_TON** in the configuration file. This variable defines the type of source address number in SMS being sent. Default value is 0. In addition, you can set the variable **ADF_SERIAL_SMPP_SRC_ADDR_TON** in the configuration file. This variable defines the type of source address number in SMS being sent. Default value is 0.
Line 73: Line 77:
 The following actions can be performed over a modem: The following actions can be performed over a modem:
-  * **delete** - delete a modem. +  * **delete** ​-- delete a modem.
-  * **begin_comm** - begin communication that is start getting data from the modem.  +  * **begin_comm** ​-- begin communication that is start getting data from the modem.
-  * **end_comm** - end communication that is stop getting data from the modem.  +  * **end_comm** ​-- end communication that is stop getting data from the modem.
-  * **accessors** - manage the access of different users to this modem. Access to modems is assigned in the same way as for users - see [[admin/​admin/​users#​access_management|Access Management]] for details. ​+  * **accessors** ​-- manage the access of different users to this modem. Access to modems is assigned in the same way as for users - see [[admin/​admin/​users#​access_management|Access Management]] for details. ​
