Differences
Link to this comparison view
Next revision
Previous revision
admin:admin:import [01/07/2011 18:18]
alek
admin:admin:import [07/10/2013 12:01]
alek
Line 12: Line 12:
 To improve upload performance,​ you may first compress files with ZIP or GZIP utility for your operating system. After upload is complete, files will be unpacked on the server and processed. To improve upload performance,​ you may first compress files with ZIP or GZIP utility for your operating system. After upload is complete, files will be unpacked on the server and processed.
-{{  :​admin:​import.png  ​|Messages import}}+{{  :​admin:​import.png?​nolink ​ }}
 Choose a destination unit in the dropdown list. Then indicate the path to its messages file. If the messages are located in several files, you can **Add File**. At the end press the **Upload** button to start the process. The result will be reported on the top.  Choose a destination unit in the dropdown list. Then indicate the path to its messages file. If the messages are located in several files, you can **Add File**. At the end press the **Upload** button to start the process. The result will be reported on the top.
Was this helpful?
Thank you!
