Differences
Link to this comparison view
Next revision
Previous revision
admin:admin:connectors [08/07/2011 12:30]
alek
admin:admin:connectors [07/10/2013 12:02]
alek
Line 4: Line 4:
 If any computers or programs are directly connected to the server at the moment, they are listed on this page. Logistics server, unit connection server or another database server can be considered as computers. A client application which requires connection to the server can be considered as a program. ​ If any computers or programs are directly connected to the server at the moment, they are listed on this page. Logistics server, unit connection server or another database server can be considered as computers. A client application which requires connection to the server can be considered as a program. ​
-{{  :​admin:​connectors.png  ​|Connectors ​}}+{{  :​admin:​connectors.png?​nolink ​ }}
-In the table you see connector'​s GUID (globally unique identifier),​ host, activation time, trusted mode, user. \\ **Trusted local** means that connected client has full access to all local objects and does not require ​authorisation. \\ **Trusted remote** shows that the server can get access to manage other computer or application without authorization and has full access to all local objects of the client. You can **disconnect** a computer or a program if needed. ​+In the table you see connector'​s GUID (globally unique identifier),​ host, activation time, trusted mode, user. \\ **Trusted local** means that connected client has full access to all local objects and does not require ​authorization. \\ **Trusted remote** shows that the server can get access to manage other computer or application without authorization and has full access to all local objects of the client. You can **disconnect** a computer or a program if needed. ​
 These parameters are set in the [[admin/​variables/​start|configuration file]], variable ADF_STORAGE_NET_SERVER. ​ These parameters are set in the [[admin/​variables/​start|configuration file]], variable ADF_STORAGE_NET_SERVER. ​
