Differences
Link to this comparison view
admin:admin:connections [29/03/2013 12:28]
127.0.0.1 external edit
admin:admin:connections [07/10/2013 12:05] (current)
alek
Line 2: Line 2:
 ====== Connections ====== ====== Connections ======
-Active connections are displayed on this page (equipment connected to the server at the moment). In the table you see hardware type, connection type, host and port, unit name, time when connected. As needed, an item cam be disconnected. ​+Active connections are displayed on this page (equipment connected to the server at the moment). In the tableyou see hardware type, connection type, host and port, unit name, time when connected. As needed, an item can be disconnected. ​
-Choose Device Type from the dropdown list. All connections ​which involve this kind of device will be displayed. Indicate also Connection Type as needed (TCP, UDP or any). +Choose Device Type from the dropdown list. All connections ​that involve this kind of device will be displayed. Indicate also Connection Type as needed (TCP, UDP or any).
 To make your query more precise, use unit name/ID mask in the Unit text field. After entering or changing the mask, press <​ENTER>​. ​ To make your query more precise, use unit name/ID mask in the Unit text field. After entering or changing the mask, press <​ENTER>​. ​
-According to the formulated request the corresponding connections will be displayed. In the table you see device type, link type, host, port, unit name (and unit ID in brackets), last run time, the button to disconnect device from the server. ​+According to the formulated requestthe corresponding connections will be displayed. In the table you see device type, link type, host, port, unit name (and unit ID in brackets), last run time, the button to disconnect device from the server. ​
-{{  :​admin:​connections.png?​nolink  ​|Connections ​}}+{{  :​admin:​connections.png?​nolink ​ }}
