Differences
Link to this comparison view
user:units:manage [10/09/2019 17:17]
tagr
user:units:manage [11/09/2019 08:37] (current)
tagr
Line 5: Line 5:
 To create a unit, click //New//, fill in the fields of [[:​cms/​units/​general|general properties]],​ and press //OK//. The created unit appears in the worklist. In addition, a unit created in the monitoring system or CMS Manager automatically appears in the worklist of the //​Monitoring//​ panel (in the [[user/​monitor/​list#​simple_list_mode|simple list mode]]) of the account it has been created in. To create a unit, click //New//, fill in the fields of [[:​cms/​units/​general|general properties]],​ and press //OK//. The created unit appears in the worklist. In addition, a unit created in the monitoring system or CMS Manager automatically appears in the worklist of the //​Monitoring//​ panel (in the [[user/​monitor/​list#​simple_list_mode|simple list mode]]) of the account it has been created in.
-Units are listed in the alphabetic ​order. Each unit has an icon. To quickly find the required unit, use the dynamic filter. Such information as the unit type, unique ID, and phone number(s) can be found in the unit's tooltip. To view the unit's tooltip, the //Edit connectivity settings// [[cms/​rights/​rights#​access_levels|right]] ​towards ​the unit is required.+Units are listed in alphabetical ​order. Each unit has an icon. To quickly find the required unit, use the dynamic filter. Such information as the unit type, unique ID, and phone number(s) can be found in the unit's tooltip. To view the unit's tooltip, the //Edit connectivity settings// [[cms/​rights/​rights#​access_levels|access ​right]] ​to the unit is required.
 Below is the list of actions you can perform right from the panel. Below is the list of actions you can perform right from the panel.
Line 28: Line 28:
 {{:​icons:​copy.png?​nolink}}:​ create a new unit based on the selected unit.  {{:​icons:​copy.png?​nolink}}:​ create a new unit based on the selected unit.
-{{:​icons:​del.png?​nolink}}:​ delete the unit from the system. ​If the icon is disabled, it means you do not possess ​enough access rights ​to perform the action.+{{:​icons:​del.png?​nolink}}:​ delete the unit from the system. ​The button ​is disabled ​if there are not enough access rights.
