Differences
Link to this comparison view
user:trailers:usage [29/08/2019 16:54]
tagr
user:trailers:usage [06/09/2019 09:22] (current)
tagr [Usage of Trailers]
Line 6: Line 6:
   * Trailers can be displayed in the //​[[user/​monitor/​monitor|Monitoring]]//​ panel. ​   * Trailers can be displayed in the //​[[user/​monitor/​monitor|Monitoring]]//​ panel. ​
-  * Trailers can be displayed in [[:​user/​monitor/​extra|additional information]] of the unit if this option is activated in the //General Settings// tab of the //User Settings// ​dialogue ​box. +  * Trailers can be displayed in [[:​user/​monitor/​extra|additional information]] of the unit if this option is activated in the //General Settings// tab of the //User Settings// ​dialog ​box.
   * Trailers can be displayed on the map. Even though they do not have their own coordinates,​ the location of the trailer can be defined with the help of the unit to which the trailer is bound. To see the trailer on the map, check the box with its name in the left column in the trailer panel. If the trailer is bound to the unit, it is displayed in the lower right corner of the unit's icon. If the trailer is not bound to the unit, the last known position is displayed.   * Trailers can be displayed on the map. Even though they do not have their own coordinates,​ the location of the trailer can be defined with the help of the unit to which the trailer is bound. To see the trailer on the map, check the box with its name in the left column in the trailer panel. If the trailer is bound to the unit, it is displayed in the lower right corner of the unit's icon. If the trailer is not bound to the unit, the last known position is displayed.
