Differences
Link to this comparison view
Next revision
Previous revision
user:set:maps [14/05/2018 09:29]
tagr [Maps]
user:set:maps [23/10/2018 09:31] (current)
tagr WH-410
Line 9: Line 9:
 Here you can enable or disable certain layers of maps by checking the appropriate boxes. Changes are applied after clicking //OK// and refreshing the page. To select a different map as a base layer, choose it in the [[user/​gui/​map#​map_source|maps menu]]. ​ Here you can enable or disable certain layers of maps by checking the appropriate boxes. Changes are applied after clicking //OK// and refreshing the page. To select a different map as a base layer, choose it in the [[user/​gui/​map#​map_source|maps menu]]. ​
-The following maps can be used in Wialon: Google, Bing, Kosmosnimki,​ 2GIS, WikiMapia, Visicom, Yandex, HERE, Regio, Luxena, what3words, MyIndia, ArcGIS, GoMap.az, Mapbox, OpenStreetMap, ​OpenSeaMap (additional layers). Besides, Gurtam Maps are available by default. ​+The following maps can be used in Wialon: Google, Bing, Kosmosnimki,​ 2GIS, WikiMapia, Visicom, Yandex, HERE, Regio, Luxena, what3words, MyIndia, ArcGIS, GoMap.az, Mapbox, OpenStreetMap, ​and additional layers ​OpenSeaMap, OpenWeatherMap,​ AerisWeather.Besides, Gurtam Maps are available by default. ​
 Some maps go in blocks. For example, when you enable Google Maps, several map layouts appear on the menu at once: Google Streets, Google Physical, Google Satellite, Google Hybrid, Google Map Maker, Google Map Maker Hybrid, and Google Street View for [[user/​monitor/​minimap#​mini_map_modes|tracking on mini map]]. Moreover, if the additional layers are available (for example, traffic layer, maritime navigation),​ they can be visually displayed on top of any chosen map. Some maps go in blocks. For example, when you enable Google Maps, several map layouts appear on the menu at once: Google Streets, Google Physical, Google Satellite, Google Hybrid, Google Map Maker, Google Map Maker Hybrid, and Google Street View for [[user/​monitor/​minimap#​mini_map_modes|tracking on mini map]]. Moreover, if the additional layers are available (for example, traffic layer, maritime navigation),​ they can be visually displayed on top of any chosen map.
-If there is no option to activate a map type, address your request to [[http://​support.gurtam.com|Gurtam Help System]].\\ :!: Use of cartographic services is stipulated by the procedures established by the author or by other rightholder ​of such services. When choosing a cartographic service you confirm that you acknowledge and accept the full responsibility for its possible misuse.+If there is no option to activate a map type, address your request to [[http://​support.gurtam.com|Gurtam Help System]].\\ :!: Use of cartographic services is stipulated by the procedures established by the author or by another right holder ​of such services. When choosing a cartographic service you confirm that you acknowledge and accept the full responsibility for its possible misuse.
 **Geodata source**\\ **Geodata source**\\
-In this section you can select the source of address information used in the //​Monitoring//​ panel, in the tooltips of units and tracks, in the //​Messages//​ panel, while creating geofences and routes. Possible sources of geodata are Gurtam, Google, Visicom, Yandex, Mapbox, HERE, Luxena, what3words, ArcGIS. Only the maps that are activated in the site's properties are displayed in the list of available.  ​+In this sectionyou can select the source of address information used in the //​Monitoring//​ panel, in the tooltips of units and tracks, in the //​Messages//​ panel, while creating geofences and routes. Possible sources of geodata are Gurtam, Google, Visicom, Yandex, Mapbox, HERE, Luxena, what3words, ArcGIS. Only the maps that are activated in the site's properties are displayed in the list of available.  ​
-:!: If a geodata source other than Gurtam is chosen, the //Address format// block becomes unavailable.  ​+If //Google (standard)//​ or //Yandex (standard) — geocoding// [[cms/​accounts/​services?​|service]] is activated for the account and Google or Yandex is selected as the geodata source, the information about the location of the unit is shown in the reports in accordance with the format of the maps provider.
 +For the Gurtam geodata source, it is possible to activate the //MGRS coordinates//​ option if the user has the //MGRS// [[cms/​accounts/​services|service]].
 +:!: If a geodata source other than Gurtam is chosen, the //Address format// block becomes unavailable.  ​
 **Address format**\\ **Address format**\\
Line 24: Line 28:
 This format is especially relevant if the units are moving around the city. For addresses outside the city (near roads), the following two settings are important: This format is especially relevant if the units are moving around the city. For addresses outside the city (near roads), the following two settings are important:
-  * //Max distance from unit// determines that if the unit is on thew road or close to it and there is a city/​town/​village at a specified distance, the address is displayed as the name of the road and the distance to that city (if several cities are found, then to the nearest one). +  * //Max distance from unit// determines that if the unit is on the road or close to it and there is a city/​town/​village at a specified distance, the address is displayed as the name of the road and the distance to that city (if several cities are found, then to the nearest one).
   * //Min city radius// determines that if at a distance specified as //Max distance from unit//, no settlement is found, then the address is bound to some other city. The radius of the city that can get into the address information can be specified in this parameter. It may be necessary, for example, if only large cities should appear in addresses.   * //Min city radius// determines that if at a distance specified as //Max distance from unit//, no settlement is found, then the address is bound to some other city. The radius of the city that can get into the address information can be specified in this parameter. It may be necessary, for example, if only large cities should appear in addresses.
