Differences
Link to this comparison view
user:reports:tables:summary [14/05/2018 07:01]
tagr [Summary]
user:reports:tables:summary [01/10/2018 09:01] (current)
tagr
Line 20: Line 20:
   * **Custom sensor initial value** — the custom sensor value at the beginning of the interval. If there are more than one custom sensors, a separate column is built for each of them and the name is written in brackets. The name masks of custom sensors can be indicated on the right-hand side of the template dialog. ​   * **Custom sensor initial value** — the custom sensor value at the beginning of the interval. If there are more than one custom sensors, a separate column is built for each of them and the name is written in brackets. The name masks of custom sensors can be indicated on the right-hand side of the template dialog. ​
   * **Custom sensor final value** — the value of the custom sensor at the end of the interval. ​   * **Custom sensor final value** — the value of the custom sensor at the end of the interval. ​
-  * **Difference** — the difference between the initial and final values of custom sensor.+  * **Difference** — the difference between the initial and final values of the custom sensor.
   * **Utilization** — the percentage ratio of the duration of engine hours to the engine hours rate (engine hours divided by daily engine hours rate indicated in the unit properties).   * **Utilization** — the percentage ratio of the duration of engine hours to the engine hours rate (engine hours divided by daily engine hours rate indicated in the unit properties).
   * **Useful utilization** — the percentage ratio of the duration of engine efficiency to the engine hours rate.   * **Useful utilization** — the percentage ratio of the duration of engine efficiency to the engine hours rate.
Line 28: Line 28:
   * **Avg consumption** — the average fuel consumption by any sort of fuel sensor. If several such sensors are available, their values sum up.    * **Avg consumption** — the average fuel consumption by any sort of fuel sensor. If several such sensors are available, their values sum up.
   * **Avg consumption by...** — the average fuel consumption on the interval. More details about the fuel in reports can be found [[user/​reports/​dat/​dat#​fuel_in_reports|here]]. ​   * **Avg consumption by...** — the average fuel consumption on the interval. More details about the fuel in reports can be found [[user/​reports/​dat/​dat#​fuel_in_reports|here]]. ​
-  * **Avg mileage per unit of fuel by ...** — the average mileage per unit of fuel based on the indications of a particular sensor.  ​+  * **Avg mileage per unit of fuel by ...** — the average mileage per unit of fuel based on the indications of a particular sensor.  ​
   * **Initial fuel level** — the counter value at the beginning of the interval. ​   * **Initial fuel level** — the counter value at the beginning of the interval. ​
   * **Final fuel level** — the counter value at the end of the interval. ​   * **Final fuel level** — the counter value at the end of the interval. ​
   * **Total fillings** — the number of the detected fuel fillings. ​   * **Total fillings** — the number of the detected fuel fillings. ​
-  * **Total thefts** — the number of the detected ​ fuel thefts. ​+  * **Total thefts** — the number of the detected fuel thefts. ​
   * **Filled** — the volume of filled fuel (only fuel fillings detected by a sensor).   * **Filled** — the volume of filled fuel (only fuel fillings detected by a sensor).
   * **Stolen** — the volume of stolen fuel.    * **Stolen** — the volume of stolen fuel.
