Differences
Link to this comparison view
Next revision
Previous revision
user:reports:tables:speedings [14/05/2018 06:57]
tagr
user:reports:tables:speedings [01/10/2018 08:59] (current)
tagr
Line 6: Line 6:
   * **Beginning** — the date and time when the speed limit was exceeded. ​   * **Beginning** — the date and time when the speed limit was exceeded. ​
   * **Location** — the location of the device at the moment of speeding. ​   * **Location** — the location of the device at the moment of speeding. ​
-  * **Duration** — the amount of time the violation continued+  * **Duration** — the time interval during which the unit was moving with an excessive speed. If the speeding was determined by one message, in the line //00:00// is written. In order the speeding to be determined also by one message, it is necessary to indicate //0// as the minimum speeding time in the [[/​cms/​units/​adv#​speeding|advanced properties]] of the unit.
   * **Total time** — the time from the beginning of the first speeding to the end of the last speeding. ​   * **Total time** — the time from the beginning of the first speeding to the end of the last speeding. ​
   * **Max speed** — the maximum speed within the period of speeding.   * **Max speed** — the maximum speed within the period of speeding.
Line 12: Line 12:
   * **Mileage** — the distance traveled with the exceeded speed. ​   * **Mileage** — the distance traveled with the exceeded speed. ​
   * **Mileage (adjusted)** — the mileage subject to the coefficient set in unit properties (the //​Advanced//​ tab).   * **Mileage (adjusted)** — the mileage subject to the coefficient set in unit properties (the //​Advanced//​ tab).
-  * **Initial mileage** — the mileage sensor value at the moment of beginning of speeding. If no saving of mileage parameter was made through the reported period, ​then mileage is counted from 0. +  * **Initial mileage** — the mileage sensor value at the moment of the beginning of speeding. If no saving of mileage parameter was made through the reported period, ​the mileage is counted from 0.
-  * **Final mileage** — mileage sensor value at the end of speeding interval.+  * **Final mileage** — mileage sensor value at the end of the speeding interval.
   * **Avg speed** — the average speed within the interval. ​   * **Avg speed** — the average speed within the interval. ​
   * **Driver** — the name of the driver (if identified). ​   * **Driver** — the name of the driver (if identified). ​
