Differences
Link to this comparison view
user:reports:tables:rounds [01/10/2018 11:49]
tagr
user:reports:tables:rounds [08/01/2019 16:40] (current)
tagr [Rounds (for unit)]
Line 11: Line 11:
   * **End** — the end time of the round (entrance to the last point). ​   * **End** — the end time of the round (entrance to the last point). ​
   * **Final location** — the unit location at the end of the route. ​   * **Final location** — the unit location at the end of the route. ​
-  * **Result** — //​Finished//​ (the route was activated successfully,​ and later on the entrance to the last point was detected) ​or //Not finished// (the last point was not visited). ​+  * **Result** — //​Finished//​ (the route was activated successfully,​ and later on the entrance to the last point was detected)//Not finished// (the last point was not visited) or //Aborted// (the round has been removed from the table manually or its expiration time has been reached).
   * **Skipped points** — the number of skipped checkpoints (a detailed report can be generated — [[points|]]). ​   * **Skipped points** — the number of skipped checkpoints (a detailed report can be generated — [[points|]]). ​
   * **Duration** — the time taken to perform the route. ​   * **Duration** — the time taken to perform the route. ​
