Differences
Link to this comparison view
user:reports:tables:fields [11/01/2018 08:47]
tagr [Custom Fields]
user:reports:tables:fields [11/05/2018 09:06] (current)
Line 2: Line 2:
 ====== Custom Fields ====== ====== Custom Fields ======
-The //Custom fields// table represents a list of custom fields available on the corresponding tab of the unit properties dialog (see [[cms/​units/​fields|Unit Properties ​=> Custom Fields]]). ​ +The //Custom fields// table represents a list of custom fields available on the corresponding tab of the unit properties dialog (see [[cms/​units/​fields|Unit Properties ​> Custom Fields]]). To get this report, you need the //View custom fields// and/or //View admin fields// access to a unit/​user/​unit group. The type of fields is selected in the right part of the report template dialog (all/​general/​admin fields). ​
-To get this report, you need the //View custom fields// and/or //View admin fields// access to a unit/​user/​unit group. The type of fields is selected in the right part of the report template dialog (all/​general/​admin fields). ​+
 Possible columns: ​ Possible columns: ​
Line 14: Line 12:
 {{ :​tables:​fields.png?​nolink }} {{ :​tables:​fields.png?​nolink }}
-There is no point to apply such additional parameters as grouping, the //Total// row and numbering to this kind of report. It does not matter what interval you choose for the report, because only the current fields contained in the unit properties can be displayed.  +To get custom fields for a unit group (see [[user/​reports/​adv/​adv|]]),​ make sure the //​Detalization//​ option is enabled. Note that individual fields of each unit are displayed and not the fields of the selected unit group. To display group fields in the report template, activate the //Group itself// option. ​
-To get custom fields for a unit group (see [[user/​reports/​adv/​adv|]]),​ make sure the //​Detalization//​ option is enabled. Note that individual fields of each unit will be displayed and not the fields of the selected unit group. To display group fields in the report template, activate the //Group itself// option. ​+
