Differences
Link to this comparison view
user:reports:dat:fuel:detect_thefts [30/11/2018 12:51]
tagr [Thefts Detection]
user:reports:dat:fuel:detect_thefts [07/02/2020 11:50] (current)
mary [Calculate theft volume by raw data] chdi
Line 26: Line 26:
 =====Calculate theft volume by raw data===== =====Calculate theft volume by raw data=====
   'Unit properties'​ → 'Fuel consumption'​ → 'Fuel Fillings/​Thefts Detection'​ block → '​Calculate theft volume by raw data'   'Unit properties'​ → 'Fuel consumption'​ → 'Fuel Fillings/​Thefts Detection'​ block → '​Calculate theft volume by raw data'
-Similar to fillings, the filtration may deviate the start and the end fuel level values of thefts. To ignore such deviations, the system uses unfiltered data while calculating the volume of theft.+Similar to fillings, the filtration may deviate the start and the end fuel level values of thefts. To ignore such deviations, the system uses unfiltered data while calculating the volume of theft. This option is applied only when the value before the filtration exceeds the value obtained as a result of filtration.
 =====Special Case: How a fuel theft is detected?​===== =====Special Case: How a fuel theft is detected?​=====
