Differences
Link to this comparison view
Next revision
Previous revision
user:reports:adv:group [13/05/2018 21:03]
tagr [Unit Latest Data]
user:reports:adv:group [01/10/2018 09:36] (current)
tagr
Line 7: Line 7:
 In the //Unit group// reports the following features are **available**:​ In the //Unit group// reports the following features are **available**:​
-  * Any [[user/​reports/​tables/​tables|tables]];​+  * Any [[user/​reports/​tables/​tables|tables]] ​except //Messages Tracing//;
   * [[user/​reports/​templ/​settings/​map#​graphical_elements_filtration|Graphical elements on the map:]] geofences, markers, unit last location icons, tracks and all messages on the map;    * [[user/​reports/​templ/​settings/​map#​graphical_elements_filtration|Graphical elements on the map:]] geofences, markers, unit last location icons, tracks and all messages on the map;
   * Some graphs in the [[user/​reports/​templ/​contents/​statistics/​statistics|Statistics]]:​ //Report//, //Group//, //Interval beginning//,​ //Interval end//, //Report execution time//;   * Some graphs in the [[user/​reports/​templ/​contents/​statistics/​statistics|Statistics]]:​ //Report//, //Group//, //Interval beginning//,​ //Interval end//, //Report execution time//;
Line 31: Line 31:
 {{ :​reports:​ug-02.png?​nolink }} {{ :​reports:​ug-02.png?​nolink }}
-In addition to detalization,​ you can apply the **[[user/​reports/​templ/​contents/​tables/​parameters#​grouping|grouping]]** by years/​months/​weeks/​days/​shifts. In this case the table data is grouped by a selected time interval. If several grouping intervals are chosen, they are arranged in several levels of nesting. If grouping is set, detalization can be found on the final level of nesting, and it still shows a detailed list of events for a given unit.+In addition to detalization,​ you can apply the **[[user/​reports/​templ/​contents/​tables/​parameters#​grouping|grouping]]** by years/​months/​weeks/​days/​shifts. In this casethe table data is grouped by a selected time interval. If several grouping intervals are chosen, they are arranged in several levels of nesting. If grouping is set, detalization can be found on the final level of nesting, and it still shows a detailed list of events for a given unit.
 {{ :​reports:​ug-03.png?​nolink }} {{ :​reports:​ug-03.png?​nolink }}
Line 40: Line 40:
 ==== Unit Latest Data ==== ==== Unit Latest Data ====
-This kind of the table is available only for unit groups. As for the separate units, this information is available in the [[user/​reports/​templ/​contents/​statistics/​statistics|statistics]]. The table presents the last location and thee values of their counters.  ​+This kind of the table is available only for unit groups. As for the separate units, this information is available in the [[user/​reports/​templ/​contents/​statistics/​statistics|statistics]]. The table presents the last location and the values of their counters.  ​
 The following columns can be selected to form the table: ​ The following columns can be selected to form the table: ​
Line 58: Line 58:
 {{  :​reports:​ug-05.png?​nolink ​ }} {{  :​reports:​ug-05.png?​nolink ​ }}
-By default, the latest information refers to the time of the report execution. However, ​it can be bound at the end of the reporting ​interval. To do this, enable the **//​Consider report interval//​** checkbox in the template. ​+By default, the latest information refers to the time of the report execution. However, ​the latest information ​at the end of the report ​interval ​can also be displayed. To do this, enable the **//​Consider report interval//​** checkbox in the template. ​
 Apart from that, the [[user/​reports/​templ/​contents/​tables/​filtration|filtration]] by geofences/​units can be used for this report. This allows to quickly find the units which are situated in a certain place or close to other units. ​ Apart from that, the [[user/​reports/​templ/​contents/​tables/​filtration|filtration]] by geofences/​units can be used for this report. This allows to quickly find the units which are situated in a certain place or close to other units. ​
 The last location can be visualized on the map by unit icons — activate the //​[[user/​reports/​templ/​settings/​map#​unit_last_location|Unit last location]]//​ option in the report template. ​ The last location can be visualized on the map by unit icons — activate the //​[[user/​reports/​templ/​settings/​map#​unit_last_location|Unit last location]]//​ option in the report template. ​
