Both sides previous revision Previous revision | |||
user:notify:action [20/11/2018 12:00] tagr WH-509 |
user:notify:action [12/02/2019 13:09] (current) tagr WH-846 |
Line 19: | Line 19: | ||
Key in one or more telephone numbers in the international format, for example, +375293293294. When all slots to enter phones are filled, additional slots appear automatically. | Key in one or more telephone numbers in the international format, for example, +375293293294. When all slots to enter phones are filled, additional slots appear automatically. | ||
- | :!: Note that if the flag 'Can send SMS' is not chosen in [[:cms/users/props#general|user properties]], then the corresponding notification delivery method becomes unavailable. | + | :!: Note that if the checkbox //Can send SMS// is not activated in [[:cms/users/props#general|user properties]], then the corresponding notification delivery method becomes unavailable. |
+ | ===== Send notification to Telegram ===== | ||
+ | This method allows sending alerts about triggered notifications to the [[https://en.wikipedia.org/wiki/Telegram_(service)|Telegram]] messenger. | ||
+ | {{ :notify:notify_telegram.png?nolink }} | ||
+ | To configure sending of notifications to Telegram, perform the steps described below. | ||
+ | 1. Create a bot. | ||
+ | * Tap the //Search// icon. | ||
+ | * Find the bot named //BotFather//. | ||
+ | * Tap //Start// and follow the instructions. | ||
+ | * The received token must be specified in the //Bot key// field. | ||
+ | {{ :notify:bot_name.png?nolink }} | ||
+ | 2. Tap //Start// to subscribe to the created bot. | ||
+ | 3. Find out the user ID. | ||
+ | * Find the bot named //userinfobot//. | ||
+ | * Tap //Start//. | ||
+ | * If you have found the correct bot, you should receive a message with the user ID. In order to find out the ID of another user, forward any of their messages to the bot. Indicate the received ID in the //Channel ID// field. | ||
===== Display online notification in a popup window ===== | ===== Display online notification in a popup window ===== | ||
Line 42: | Line 64: | ||
===== Send mobile notification ===== | ===== Send mobile notification ===== | ||
- | In this case upon notification triggering a mobile notification is sent to a user/users of an application. Choose the necessary application in the upper field. Then the system checks the possession of the necessary rights towards users: 'View detailed item properties', 'Act as given user'. Current user as well as the creator of a resource to which a notification belongs are checked for the possession of these rights. Afterwards on the basis of this check a list of users is formed in the field below. Here you can indicate a user/multiple users (choosing the corresponding flags) or all the users (holding <ctrl> and checking any user's flag) to whom a notification will be sent. To facilitate the search, you can use the dynamic filter. | + | In this case upon notification triggering a mobile notification is sent to a user/users of an application. Choose the necessary application in the upper field. Then the system checks the possession of the necessary rights towards users: 'View detailed item properties', 'Act as given user'. Current user, as well as the creator of a resource to which a notification belongs, are checked for the possession of these rights. Afterwards on the basis of this check a list of users is formed in the field below. Here you can indicate a user/multiple users (choosing the corresponding flags) or all the users (holding <ctrl> and checking any user's flag) to whom a notification will be sent. To facilitate the search, you can use the dynamic filter. |
Note that mobile notifications service availability depends on the chosen [[cms/accounts/services#list_of_services|service package]]. | Note that mobile notifications service availability depends on the chosen [[cms/accounts/services#list_of_services|service package]]. |
