Differences
Link to this comparison view
user:msg:port [12/06/2018 11:12]
tagr [Export]
user:msg:port [28/09/2018 10:47] (current)
tagr
Line 4: Line 4:
 Messages can be imported and exported. It concerns only the messages of the first type, that is, [[data|data messages]]. ​ Messages can be imported and exported. It concerns only the messages of the first type, that is, [[data|data messages]]. ​
-:!: //​Attention!//​\\ The size limit for the imported file/​archive is 64 MB, which, in case of the archive, is approximately 3.5 million messages. ​ +:!: //​Attention!//​\\ The size limit for the imported file/​archive is 64 MB, which, in the case of the archive, is approximately 3.5 million messages. ​
 ===== Export ===== ===== Export =====
Line 29: Line 28:
 The supported import formats are: The supported import formats are:
-  * Raw GPRMC navigator logs in format defined by NMEA 0183 specification — searched in files with the extension .txt or .log.+  * Raw GPRMC navigator logs in the format defined by NMEA 0183 specification — searched in files with the extension .txt or .log.
   * Wialon messages — search in files with the extension .wln.   * Wialon messages — search in files with the extension .wln.
