Differences
Link to this comparison view
Last revision Both sides next revision
user:msg:manage [22/08/2018 17:22]
tagr [Viewing Messages]
user:msg:manage [28/09/2018 10:42]
tagr
Line 7: Line 7:
 The request is formulated in the //​[[msg|]]//,​ in the top left corner of the window. Specify the following parameters: The request is formulated in the //​[[msg|]]//,​ in the top left corner of the window. Specify the following parameters:
-  - Select a unit. The dropdown list contains not all the units available to you, but only the units from the [[user/​monitor/​list|work list]] of the monitoring panel. In case the work list is empty (when the [[user/​monitor/​list#​dynamic_work_list|dynamic work list]] is used or when units were deleted from the work list manually), the units to which you possess the corresponding rights are displayed. The button in the shape of a spanner located to the right of the dropdown list serves to open the [[cms/​units/​units#​unit_properties_dialog|Unit Properties dialog]].\\ ​+  - Select a unit. The dropdown list contains not all the units available to you, but only the units from the [[user/​monitor/​list|work list]] of the monitoring panel. In case the worklist ​is empty (when the [[user/​monitor/​list#​dynamic_work_list|dynamic work list]] is used or when units were deleted from the work list manually), the units to which you possess the corresponding rights are displayed. The button in the shape of a spanner located to the right of the dropdown list serves to open the [[cms/​units/​units#​unit_properties_dialog|Unit Properties dialog]].\\ ​
   - Specify the time interval to show messages for.{{ ​ :​msg:​query.png?​nolink}} The principle of interval adjustment is the same as in the reports (see [[../​reports/​query/​query|]]). The second and fourth steps can be combined if you choose one of the //quick intervals// (the buttons //Today//, //​Yesterday//,​ //Week//, and //Month//). \\    - Specify the time interval to show messages for.{{ ​ :​msg:​query.png?​nolink}} The principle of interval adjustment is the same as in the reports (see [[../​reports/​query/​query|]]). The second and fourth steps can be combined if you choose one of the //quick intervals// (the buttons //Today//, //​Yesterday//,​ //Week//, and //Month//). \\
   - Select the message type from the dropdown list (each type is described in detail below):​\\  ​   - Select the message type from the dropdown list (each type is described in detail below):​\\  ​
Line 28: Line 28:
 Messages of any type are displayed in the form of a table. ​ Messages of any type are displayed in the form of a table. ​
-If a long time interval is selected, there can be many messages. In this case they are presented on several pages. Use the navigation panel (blue arrows) to move from page to page, or enter the page number manually and press //Enter// to display a certain page. Apart from that, in the dropdown list you can set the number of messages to be displayed on one page: 25, 50, 100, 500, 1000.  ​+If a long time interval is selected, there can be many messages. In this casethey are presented on several pages. Use the navigation panel (blue arrows) to move from page to page, or enter the page number manually and press //Enter// to display a certain page. Apart from that, in the dropdown listyou can set the number of messages to be displayed on one page: 25, 50, 100, 500, 1000.  ​
 {{ :​msg:​table.png?​nolink }} {{ :​msg:​table.png?​nolink }}
Line 34: Line 34:
 To change the chronological order of the messages, click on the heading of the //Time// column. The current sorting direction is shown by the arrows: {{:​icons:​arrow-down.png?​nolink}} — for the direct order; {{:​icons:​arrow-up.png?​nolink}} — for the reverse one. This setting is remembered by the system and used until you change it manually. To change the chronological order of the messages, click on the heading of the //Time// column. The current sorting direction is shown by the arrows: {{:​icons:​arrow-down.png?​nolink}} — for the direct order; {{:​icons:​arrow-up.png?​nolink}} — for the reverse one. This setting is remembered by the system and used until you change it manually.
-The width of the columns can be adjusted. To do this, move the cursor to the border of the column, click the left mouse button andwhile holding it, drag the border to the desired direction. If you want to expand the table, press the //Set column auto width// button so that the letter //A// appears there {{:​icons:​autowidth.gif?​nolink}}. In this case, the column width will be set according to contents in the cells. To save the column width when moving through the pages, make the button inactive {{:​icons:​autowidth0.gif?​nolink}}. Note that when loading many messages (500, 1000 per page), it is better to disable the column auto width because it can considerably slow down the loading process especially if the number of parameters differs from one message to another. ​+The width of the columns can be adjusted. To do this, move the cursor to the border of the column, click the left mouse button and while holding it, drag the border to the desired direction. If you want to expand the table, press the //Set column auto width// button so that the letter //A// appears there {{:​icons:​autowidth.gif?​nolink}}. In this case, the column width will be set according to contents in the cells. To save the column width when moving through the pages, make the button inactive {{:​icons:​autowidth0.gif?​nolink}}. Note that when loading many messages (500, 1000 per page), it is better to disable the column auto width because it can considerably slow down the loading process especially if the number of parameters differs from one message to another. ​
 The contents of the table are adjustable. It is possible to hide and display any column. To display the columns, click the {{:​icons:​customizer.png?​nolink}} button in the right corner of the header of the table. Then select the columns you need in the dropdown list. Note that all the columns cannot be hidden simultaneously. If sensors are displayed, each of them has its own column that can be enabled or disabled. By default, only [[cms/​units/​sensors/​sensors|visible sensors]] are displayed (the rest can be enabled manually). The set of columns and their width are only saved for one unit during one session. If the unit or message type is changed, or the page is refreshed, the settings are reset. The contents of the table are adjustable. It is possible to hide and display any column. To display the columns, click the {{:​icons:​customizer.png?​nolink}} button in the right corner of the header of the table. Then select the columns you need in the dropdown list. Note that all the columns cannot be hidden simultaneously. If sensors are displayed, each of them has its own column that can be enabled or disabled. By default, only [[cms/​units/​sensors/​sensors|visible sensors]] are displayed (the rest can be enabled manually). The set of columns and their width are only saved for one unit during one session. If the unit or message type is changed, or the page is refreshed, the settings are reset.
Line 44: Line 44:
 The rules for setting the filter were given [[user/​gui/​masks#​name_mask|above]]. You can use wildcard characters (* or ?) or input your query without them. For example, to find all messages with images enter '​image'​. Other available parameters depend on the type of equipment used.  The rules for setting the filter were given [[user/​gui/​masks#​name_mask|above]]. You can use wildcard characters (* or ?) or input your query without them. For example, to find all messages with images enter '​image'​. Other available parameters depend on the type of equipment used.
-To search for several parameters at once, enter their masks separated by commas. In this case, the results are highlighted in different ​colours ​and moved to the beginning of the line. Their order corresponds to the entered masks. ​+To search for several parameters at once, enter their masks separated by commas. In this case, the results are highlighted in different ​colors ​and moved to the beginning of the line. Their order corresponds to the entered masks. ​
 For parameter values, the usage of the //*// and //?// signs is supported if string values are compared. That is, the search can be specified as: //adc? = 0.5 *//. Only operators //=// (equal) and //<>//​ (not equal) are used in this case. For parameter values, the usage of the //*// and //?// signs is supported if string values are compared. That is, the search can be specified as: //adc? = 0.5 *//. Only operators //=// (equal) and //<>//​ (not equal) are used in this case.
Line 72: Line 72:
 In the last column of the table, mark the messages that should be deleted (one or more). Then click the //Delete// button {{:​icons:​del.png?​nolink}} and confirm your intentions. If the checkbox in the header of the table is ticked, all messages on the current page will be selected. ​ In the last column of the table, mark the messages that should be deleted (one or more). Then click the //Delete// button {{:​icons:​del.png?​nolink}} and confirm your intentions. If the checkbox in the header of the table is ticked, all messages on the current page will be selected. ​
-After the operation, the newly deleted messages still remain in the tablebut become inactive. The next time when you load messages, the deleted messages will be completely removed from the database. ​+After the operation, the newly deleted messages still remain in the table but become inactive. The next time when you load messages, the deleted messages will be completely removed from the database. ​
 :!: //​Note.//​\\ ​ :!: //​Note.//​\\ ​
 It is impossible to delete the last incoming message, as well as the last message with the position (valid coordinates). That is why the delete checkbox for these messages is always dimmed. ​ It is impossible to delete the last incoming message, as well as the last message with the position (valid coordinates). That is why the delete checkbox for these messages is always dimmed. ​
