Differences
Link to this comparison view
Next revision
Previous revision
user:monitor:display [02/07/2018 17:25]
tagr [Other Markings]
user:monitor:display [04/01/2019 14:29] (current)
tagr zark
Line 3: Line 3:
 ====== Unit Presentation on Map ====== ====== Unit Presentation on Map ======
-By default, ​the unit on the map is displayed by the [[cms/​units/​image|icons assigned to them]] and their names (captions color is red). Icons for units can be selected from a standard set, e.g. {{:​icons:​standard.png?​nolink}},​ or you can upload your own image using the [[cms/​units/​image|Unit Properties => Image]] ​dialog. In addition, the icon can rotate depending on the course (direction) of the unit. This feature is also defined in unit properties. ​+By default, ​unit on the map is displayed by an [[cms/​units/​image|icon assigned to it]] which is selected when the unit is configured, and a caption with its name. Icons for units can be selected from a standard set, e. g. {{:​icons:​standard.png?​nolink}},​ or you can upload your own image in the [[cms/​units/​image|Image]] ​tab. In addition, the icon can rotate depending on the course (direction) of the unit. This feature is also defined in the unit properties. ​
 {{ :​monitor:​rotation.png?​nolink }} {{ :​monitor:​rotation.png?​nolink }}
-{{  :​icons:​group.png?​nolink}}Icons ​overlapping ​each other on the map can be replaced by the common icon with a number indicator. To do this, select //​[[:​user/​set/​general#​unit_visualization_on_map|Display overlapping units in one icon]]// in the //User Settings// dialog.+{{  :​icons:​group.png?​nolink}}Icons ​that overlap ​each other on the map can be replaced by the common icon with a number indicator. To do this, select //​[[:​user/​set/​general#​unit_visualization_on_map|Display overlapping units in one icon]]// in the //User Settings// dialog.
 ===== Alternatives for Icons ===== ===== Alternatives for Icons =====
-Unit icons can be replaced with motion state signs. This option is called //Replace unit icons with motion state signs// and is set in [[user/​set/​general#​unit_visualization_on_map|User Settings]]. The following symbols are possible:+Unit icons can be replaced with the motion state signs. This option is called //Replace unit icons with motion state signs// and is set in the [[user/​set/​general#​unit_visualization_on_map|User Settings]]. The following symbols are possible:
   * green arrow — the unit is moving, the direction of the arrow indicates the direction of movement;   * green arrow — the unit is moving, the direction of the arrow indicates the direction of movement;
   * red square — the unit is not moving (if there is an ignition [[cms/​units/​sensors/​sensors|sensor]],​ it also means that the unit is standing with the engine off);   * red square — the unit is not moving (if there is an ignition [[cms/​units/​sensors/​sensors|sensor]],​ it also means that the unit is standing with the engine off);
-  * yellow circle — the unit is not moving ​with the engine on (only for units that have ignition sensors).+  * yellow circle — the unit is standing ​with the engine on (only for units with ignition sensors).
 {{ :​monitor:​signs.png?​nolink }} {{ :​monitor:​signs.png?​nolink }}
-Besides, the colors of these icons (arrow, square, circle) can be different and depend on the value of sensor. This functionality is adjusted ​on the //​[[:​cms/​units/​adv#​usage_of_sensor_colors|Advanced]]//​ tab of unit properties. In other words, the shape of the icon is defined by the state (standing still — square, moving — arrow), and the color depends on the sensor value (intervals and colors are adjusted in [[:​cms/​units/​sensors/​props#​intervals_and_colors|sensor properties]]). ​+Besides, the colors of these icons (arrow, square, circle) can be different and depend on the value of the sensor. This functionality is adjusted ​in the //​[[:​cms/​units/​adv#​usage_of_sensor_colors|Advanced]]//​ tab of the unit properties. In other words, the shape of the icon is defined by the state (standing still — square, moving — arrow), and the color depends on the sensor value (intervals and colors are adjusted in the [[:​cms/​units/​sensors/​props#​intervals_and_colors|sensor properties]]). ​
 Unit names can be shown or hidden when displaying a unit on the map. It depends on the state of the ({{:​icons:​name.png?​nolink}}) button in the [[:​user/​gui/​map#​visible_layers|layers menu]] on the map. Unit names can be shown or hidden when displaying a unit on the map. It depends on the state of the ({{:​icons:​name.png?​nolink}}) button in the [[:​user/​gui/​map#​visible_layers|layers menu]] on the map.
Line 23: Line 24:
 ===== Displaying Inactive Units ===== ===== Displaying Inactive Units =====
-Monitoring units are conditionally ​divided into active and inactive ones. Inactive units are those units from which there have been no messages with data for more than 48 hours. Other units are considered active.+Monitoring units are conventionally ​divided into active and inactive ones. Inactive units are units that have not received ​messages with coordinates ​for more than 48 hours. Other units are considered active.
-The system supports the possibility of differentiating unit states on the map. To do this, check the //Blur icons of inactive units// box in [[:​user/​set/​general#​unit_visualization_on_map|user settings]]. In this case inactive units are displayed on the map with blurred icons and transparent names. If the signs of motion are used instead of icons, then transparency is used both for signs and names. If the //Display overlapping units in one icon// box is checked in //User Settings//, and all the units with overlapping icons are inactive, ​then the icon for them is displayed ​blurry. Moreover, the icons of drivers or trailers bound to the inactive unit are also blurred until they are unbound. ​+The system supports the possibility of differentiating unit states on the map. To do this, check the //Blur icons of inactive units// box in the [[:​user/​set/​general#​unit_visualization_on_map|user settings]]. In this caseinactive units are displayed on the map with blurred icons and transparent names. If the signs of motion are used instead of icons, then the signs and names are displayed as transparent. If the //Display overlapping units in one icon// box is checked in the //User Settings//, and all the units with overlapping icons are inactive, the icon for them is displayed ​blurred. Moreover, the icons of drivers or trailers bound to the inactive unit are also blurred until they are unbound. ​
 {{ :​monitor:​inactive.png?​nolink }} {{ :​monitor:​inactive.png?​nolink }}
Line 31: Line 32:
 ===== Displaying Units with LBS Detector ===== ===== Displaying Units with LBS Detector =====
-//LBS detection// is an alternative method of finding units on the map. The accuracy of this method is inferior to determining the location using GPS, but if the unit experiences troubles with GPS connection you can switch to the //LBS detection// method. To do this, it is necessary to check the //​[[cms/​units/​adv#​messages_validity_filtration|Allow positioning by cellular base stations]]//​ box on the //​Advanced//​ tab of the unit properties dialog. Therefore, if //LBS detected// data is more recent than GPS data, it is used to determine current location of the unit.+The //LBS detection// is an alternative method of finding units on the map. The accuracy of this method is inferior to determining the location using GPS, but if the unit experiences troubles with the GPS connection you can switch to the //LBS detection// method. To do this, it is necessary to check the //​[[cms/​units/​adv#​messages_validity_filtration|Allow positioning by cellular base stations]]//​ box on the //​Advanced//​ tab of the unit properties dialog. Therefore, if the //LBS detected// data is more recent than the GPS data, it is used to determine ​the current location of the unit.
-When using //LBS detection//,​ units are displayed on the map in the following way: the current icon of the unit is placed into a transparent white circle with a red dotted stroke, the brightness of the icon decreases.+When using the //LBS detection//,​ units are displayed on the map in the following way: the current icon of the unit is placed into a transparent white circle with a red dotted stroke, the brightness of the icon decreases.
 {{  :​monitor:​lbs_units.png?​nolink ​ }} {{  :​monitor:​lbs_units.png?​nolink ​ }}
Line 41: Line 42:
 {{  :​monitor:​tail.png?​nolink}} {{  :​monitor:​tail.png?​nolink}}
-If the unit is currently in motion, the green arrow shows the direction of its movement, and the unit can be followed by a blue //tail// (trace) which shows the track for the last few messages. If the unit is stationary (according to the last message), this arrow is not shown. If there was no motion within several latest messages, the trace is not shown (or the page has just been loaded). The length of the trace is 5 messages, however, it can be changed together with the trace width and color in [[user/​set/​general#​unit_visualization_on_map|User Settings]]. ​+If the unit is currently in motion, the green arrow shows the direction of its movement, and the unit can be followed by a blue //tail// (trace) which shows the track for the last few messages. If the unit is stationary (according to the last message), this arrow is not shown. If there was no motion within several latest messages, ​it means that the trace is not shown or the page has just been loaded. The length of the trace is 5 messages, however, it can be changed together with the trace width and color in the [[user/​set/​general#​unit_visualization_on_map|User Settings]]. ​
 Direction arrows, traces, the names of assigned drivers and units can be disabled. To do this, use the corresponding buttons in the [[:​user/​gui/​left#​visible_layers|layers menu]] on the map:  Direction arrows, traces, the names of assigned drivers and units can be disabled. To do this, use the corresponding buttons in the [[:​user/​gui/​left#​visible_layers|layers menu]] on the map:
Line 50: Line 51:
 {{:​icons:​course.png?​nolink}} — hide/show the direction of movement of the unit.\\ {{:​icons:​course.png?​nolink}} — hide/show the direction of movement of the unit.\\
-If the names of both units and assigned drivers are enabled simultaneously,​ the latter are shown in parenthesis. The colors of the captions are taken from the [[cms/​units/​adv#​unit_label_color|units' ​properties]]. ​+If the names of both units and assigned drivers are enabled simultaneously,​ the latter are shown in parenthesis. The colors of the captions are taken from the [[cms/​units/​adv#​unit_label_color|unit properties]].
 +The {{:​icons:​private_mode.png?​nolink}} icon to the left of the caption signals that the //​[[cms/​units/​sensors/​props|Do not show unit location]]//​ option is activated for the unit and the private mode of the trip is detected.
