Differences
Link to this comparison view
Next revision
Previous revision
user:monitor:cmd [11/09/2019 09:58]
alse [Executing Commands from the Monitoring Panel]
user:monitor:cmd [21/11/2019 13:04] (current)
mary [Sending and Tracking Commands] chdi
Line 33: Line 33:
 :!: To download the requested configuration file, use the //​[[http://​apps.wialon.com/?​lang=en#​disketta|Disketta]]//​ application (the required file is located in the //Unit// folder). To find out the name of the configuration file, generate a [[:​user/​msg/​manage#​request_messages_from_server|table with messages]] for the corresponding period. :!: To download the requested configuration file, use the //​[[http://​apps.wialon.com/?​lang=en#​disketta|Disketta]]//​ application (the required file is located in the //Unit// folder). To find out the name of the configuration file, generate a [[:​user/​msg/​manage#​request_messages_from_server|table with messages]] for the corresponding period.
-:!: If your device supports a command that is not mentioned in the list, you can send it as a //Send custom message// command. To do  this, you should know the exact name of the command as it is written in the device configuration. If you have a flespi device, ​you can [[cms/​units/​aliases?&#command_properties|create ​commands]] for it in a special form on the //​Commands//​ tab of the unit properties.+:!: If your device supports a command that is not mentioned in the list, you can send it as a //Send custom message// command. To do  this, you should know the exact name of the command as it is written in the device configuration. If you have a flespi device, ​a set of [[cms/​units/​aliases#​commands_for_flespi_devices|commands]] ​with adjustable parameters is available ​for it.
 ===== Sending and Tracking Commands ===== ===== Sending and Tracking Commands =====
Line 43: Line 43:
   * As an action for a triggered [[user/​notify/​action|notification]] (command is sent when specified conditions are met).    * As an action for a triggered [[user/​notify/​action|notification]] (command is sent when specified conditions are met).
   * From a mobile device using a plain SMS text message. ​   * From a mobile device using a plain SMS text message. ​
-  * From the [[mobile/mobile0/commands|Wialon Mobile Client]].+  * From the [[https://mobileapp.wialon.com/​android/​en/​Default.htm#​en/​Worklist.htm|app for iOS and Android]].
 :!: Such commands as //Upload configuration//​ and //Upload firmware// have their own peculiarities. If these commands have been saved for units without selecting a file, sending these commands as a job/​notification or sending them to the whole group of units is impossible. :!: Such commands as //Upload configuration//​ and //Upload firmware// have their own peculiarities. If these commands have been saved for units without selecting a file, sending these commands as a job/​notification or sending them to the whole group of units is impossible.
