Differences
Link to this comparison view
user:gui:login [25/01/2019 17:07]
tagr [Login as Another User]
user:gui:login [22/07/2019 17:50] (current)
alse [Login as Another User]
Line 47: Line 47:
 {{  :​gui:​loginas.png?​nolink}}User impersonation allows you to access and operate as if you were logged in as another (subordinate) user. To impersonate,​ you need to have the //​[[cms/​rights/​user#​special_rights|Act as given user]]// access right towards the user.  {{  :​gui:​loginas.png?​nolink}}User impersonation allows you to access and operate as if you were logged in as another (subordinate) user. To impersonate,​ you need to have the //​[[cms/​rights/​user#​special_rights|Act as given user]]// access right towards the user.
-If you would like to log in as another user from the authorization page, you need to enter your username ​and password ​and then click on the //Login as// caption and enter the name of the user in the appeared ​window. When you are logged in as another user, you can see only those items that are available to this user and perform actions allowed to this user. Note that the login history is kept in the account ​of the user under whose name the system ​has been entered.+If you want to log in as another user from the authorization page, you should ​enter your user name and passwordclick on the //Login as// caption and select ​the necessary user name in the open window. When you are logged in as another user, you can see only those objects ​that are available to them and perform ​the actions allowed to them. Note that the login history is stored ​in the account ​with which you have entered ​the system.
 You can switch to another user even after entering the system. However, in this case, the login is //not// saved in the user's history. To switch it,  click the icon {{:​icons:​login.png?​nolink}} located to the left of the username. Afterwards, the dialog containing two columns (a username and an account name) is opened. Users-creators of accounts are marked with the icon {{:​icons:​user_creator.png?​nolink|}} to the left of their names. Click on the name of the required user to authorize in the current tab, or click on the icon at the end of the line to open the page in a new tab. For the search convenience,​ it is possible to use the [[user/​gui/​masks#​dynamic_search|dynamic search]]. The search can be filtered by users or accounts. This is regulated by the filter in the upper left corner of the window. You can switch to another user even after entering the system. However, in this case, the login is //not// saved in the user's history. To switch it,  click the icon {{:​icons:​login.png?​nolink}} located to the left of the username. Afterwards, the dialog containing two columns (a username and an account name) is opened. Users-creators of accounts are marked with the icon {{:​icons:​user_creator.png?​nolink|}} to the left of their names. Click on the name of the required user to authorize in the current tab, or click on the icon at the end of the line to open the page in a new tab. For the search convenience,​ it is possible to use the [[user/​gui/​masks#​dynamic_search|dynamic search]]. The search can be filtered by users or accounts. This is regulated by the filter in the upper left corner of the window.
