Differences
Link to this comparison view
user:geo:new [05/07/2019 09:18]
alse [2. Set Geofence Properties]
user:geo:new [11/09/2019 17:35] (current)
alse
Line 9: Line 9:
 Start working with geofences by choosing the corresponding mode. Start working with geofences by choosing the corresponding mode.
-Press the **'New'​** ​button, and help window ​will provide ​you with the instructions on geofences'​ creation. Choose a geofence type on the left: //line//, //polygon// or //​circle//​. ​+Click on the //New// button. In the help windowyou can see the instructions on how to create a geofence. Choose a geofence type on the left: //line//, //polygon// or //​circle//​. ​
 Then map a geofence. Here are the basic rules for mapping a geofence: Then map a geofence. Here are the basic rules for mapping a geofence:
Line 40: Line 40:
 While creating a geofence you can include it in one or several existing geofence groups. To do this, choose the necessary geofence in the dropdown list. Use the button {{:​icons:​add.png?​nolink}} to add lines; {{:​icons:​delete.png?​nolink}} — to delete a geofence from a group.  ​ While creating a geofence you can include it in one or several existing geofence groups. To do this, choose the necessary geofence in the dropdown list. Use the button {{:​icons:​add.png?​nolink}} to add lines; {{:​icons:​delete.png?​nolink}} — to delete a geofence from a group.  ​
-**Image**\\ You can attach any image to a geofence. An image can be chosen from the standard icons (//'Icon Library'// button) or loaded from your computer by pressing the corresponding area and choosing the file you need. Supported formats are PNG, JPG, GIF, and SVG. Moreover, you can use the [[http://​apps.wialon.com/?​lang=en#​iconlibrary|Icon Library]] application (for top accounts only) which enables uploading individual icons for geofences. The icons uploaded to the system using this application will be available for you in the standard //Icon Library//. To facilitate the work with the library, the uploaded icons are placed in the same list, but separately from the standard ones (at the top). All loaded images are automatically resized by 64×64 pixels to display the geofences on the map and on the list. However, in the tooltip for a geofence you can see an enlarged image (up to 256х256 px). In the geofence’s editing dialog you can delete the image used. To do so, point a cursor on itand click the appeared ​delete button. Click OK to save changes, or Cancel to dismiss them.+**Image**\\ You can attach any image to a geofence. An image can be chosen from the standard icons (the //Icon Library// button) or loaded from your computer by pressing the corresponding area and choosing the file you need. Supported formats are PNG, JPG, GIF, and SVG. Moreover, you can use the [[http://​apps.wialon.com/?​lang=en#​iconlibrary|Icon Library]] application (for top accounts only) which enables uploading individual icons for geofences. The icons uploaded to the system using this application will be available for you in the standard //Icon Library//. To facilitate the work with the library, the uploaded icons are placed in the same list, but separately from the standard ones (at the top). All loaded images are automatically resized by 64×64 pixels to display the geofences on the map and on the list. However, in the tooltip for a geofence you can see an enlarged image (up to 256х256 px). In the geofence’s editing dialog you can delete the image used. To do so, point to it and click on the delete button. Click OK to save changes, or Cancel to dismiss them.
 **Area & Perimeter**\\ These fields are not editable, they are calculated automatically. ​ **Area & Perimeter**\\ These fields are not editable, they are calculated automatically. ​
