Differences
Link to this comparison view
Next revision
Previous revision
mobile:mobile0:track [04/07/2018 12:03]
tagr
mobile:mobile0:track [04/01/2019 12:14] (current)
tagr chdi
Line 2: Line 2:
 ====== Tracking ====== ====== Tracking ======
-There are several ways of switching to the 'Tracking' ​mode. One of them (switching from the 'Map' ​mode) has been described in the [[:​mobile/​mobile0/​map|previous section]]. The other way is to move from the work list ('Units' ​mode). To do so, tap the line of the necessary unit in the work list.+There are several ways of switching to the //Tracking// mode. One of them (switching from the //Map// mode) has been described in the [[:​mobile/​mobile0/​map|previous section]]. The other way is to move from the worklist ​(//Units// mode). To do so, tap the line of the necessary unit in the worklist.
-'Tracking' ​mode provides you with the possibility to monitor both unit's location on the map, and parameters received from a unit. Note that unit's location can be shown as address (by default) or as unit's presence in geofences ('Geofences as addresses' flag in 'Other' ​section of Wialon ​Mobile Client's settings)+The //Tracking// mode provides you with the possibility to monitor both unit's location on the map, and parameters received from a unit. Note that unit's location can be shown as an address (by default) or as unit's presence in geofences (the //Geofences as addresses// checkbox ​in the //Other// section of the Wialon ​mobile client's settings)
 {{ :​mobile:​track.png?​nolink }} {{ :​mobile:​track.png?​nolink }}
-In order the units' movement arrows to be shown on the map in the mobile client, [[user/​gui/​map#​visible_layers|activate the option]] ​'Show/Hide unit movement direction' ​in the main interface of Wialon.+In order for the units' movement arrows to be shown on the map in the mobile client, [[user/​gui/​map#​visible_layers|activate the option]] ​//Show/Hide unit movement direction// in the main interface of Wialon.
 ===== History ===== ===== History =====
-You can view unit's events on the 'History' ​tab. All the events are presented here chronologically. ​+You can view unit's events on the //History// tab. All the events are presented here chronologically ​and are formed on the basis of the messages received within 24 hours. The messages that were generated more than 24 hours ago are not registered as events after being unloaded from the black box.
 Types of events and provided information:​ Types of events and provided information:​
-{{:​icons:​mtrip.png?​nolink ​ }} \\ **Trip** \\ Event'​s start time, duration, covered distance, unit's average speed \\ +{{:​icons:​mtrip.png?​nolink ​ }} \\ **Trip** \\ Event'​s start time, duration, covered distance, unit's average speed\\
-{{:​icons:​mstill.png?​nolink ​ }} \\ **Parking** \\ Event'​s start time, duration, location address \\+{{:​icons:​mstill.png?​nolink ​ }} \\ **Parking** \\ Event'​s start time, duration, location address. The duration of the parkings which are the first and/or the last events of the day is not indicated.\\
-{{:​icons:​mfuel.png?​nolink ​ }} \\ **Fuel filling** \\ Event'​s time, amount of fuel filled, location address \\+{{:​icons:​mfuel.png?​nolink ​ }} \\ **Fuel filling** \\ Event'​s time, amount of fuel filled, location address\\
-{{:​icons:​fuel_off.png?​nolink ​ }} \\ **Fuel theft** \\ Event'​s time, amount of theft, location address \\+{{:​icons:​fuel_off.png?​nolink ​ }} \\ **Fuel theft** \\ Event'​s time, amount of theft, location address\\
-Choose ​any event in the history to display it on the map. In order the map to be centered on a unit of monitoring, tap its icon.+Choose ​an event in the history to display it on the map. In order for the map to be centered on a unit of monitoring, tap its icon.
-:!: Note that some values of event parameters (time intervals, amounts of fuel, unit's location) may differ from the values of the same parameters in the reports of the monitoring system. It occurs due to the implementation of different calculation systems in main Wialon and in Wialon ​Mobile Client. For example, upon detecting fuel fillings/​thefts,​ mobile client uses time of last message received before a fuel level changing, while main Wialon uses time of the first message from the interval with the biggest difference of fuel levels. Moreover, movement state in Wialon ​Mobile Client ​is determined only by GPS speed, while other methods can be used in main Wialon. ​+:!: Note that some values of event parameters (time intervals, amounts of fuel, unit's location) may differ from the values of the same parameters in the reports of the monitoring system. It occurs due to the implementation of different calculation systems in the web version of Wialon and in the Wialon ​mobile client. For example, upon detecting fuel fillings/​thefts, ​the mobile client uses the time of the last message received before a fuel level change, while the web version of Wialon uses time of the first message from the interval with the biggest difference of fuel levels. Moreover, ​the movement state in the Wialon ​mobile client ​is determined only by the GPS speed, while other methods can be used in the web version of Wialon. ​
-:!: Note that in Wialon ​Mobile Client ​the correctness of data received on any event depends on parameters indicated on the trip detector tab.+:!: Note that in the Wialon ​mobile client ​the correctness of the data received on any event depends on the parameters indicated on the trip detector tab.
 ===== Info ===== ===== Info =====
-The 'Info' ​tab displays ​an extended unit's information:​ location address, attached drivers (with phone numbers) and trailers, equipment data, values of custom fields, sensors, counters, and parameters.+The //Info// tab displays extended unit's information:​ location address, attached drivers (with phone numbers) and trailers, equipment data, values of custom fields, sensors, counters, and parameters.
 ===== Timeline ===== ===== Timeline =====
-On the //​Timeline//​ tab, you can visually evaluate the duration of events, find out their number and get detailed information about the grouped events (by tapping ​quantative ​indicator). Events include trips, fuel fillings and thefts. Besides, sensor state change (ignition sensor, custom digital sensor) and sensor values increase (mileage sensor, relative odometer, counter) are considered to be event types as well.+On the //​Timeline//​ tab, you can visually evaluate the duration of events ​(the exclamation mark indicates their short duration), find out their number and get detailed information about the grouped events (by tapping ​a quantitative ​indicator). Events include trips, fuel fillingsand thefts. Besides, sensor state change (ignition sensor, custom digital sensor) and sensor values increase (mileage sensor, relative odometer, counter) are considered to be event types as well.
 On the tab, you can view up to 4 event types simultaneously. Trips, fillings, and thefts are displayed by default at the bottom of the screen. To select other types, open the corresponding menu by tapping the event type at the bottom of the screen. On the tab, you can view up to 4 event types simultaneously. Trips, fillings, and thefts are displayed by default at the bottom of the screen. To select other types, open the corresponding menu by tapping the event type at the bottom of the screen.
Line 49: Line 50:
 When switching between the tabs in //​Tracking//​ section, the events disappear from the map. Go back to the //​Timeline//​ tab to return the events to the map. When switching between the tabs in //​Tracking//​ section, the events disappear from the map. Go back to the //​Timeline//​ tab to return the events to the map.
-:!: The maximum number of events that can be  simultaneously displayed on the map is 10.+:!: The maximum number of events that can be simultaneously displayed on the map is 10.
-The events selected for display on the map are added to the event cache. To see the cache, tap the {{:​icons:​event_cache.png?​nolink}} icon in the upper right corner of the screen. After tapping on the event, the map will center ​on it. It is possible to remove one or several events from the cache (tap the delete icon next to its name) or all events at once (tap //Remove all//). The event cache is cleared if you change the type of events available for display.+The events selected for display on the map are added to the event cache. To see the cache, tap the {{:​icons:​event_cache.png?​nolink}} icon in the upper right corner of the screen. After tapping on the event, the map centers ​on it. It is possible to remove one or several events from the cache (tap the delete icon next to its name) or all events at once (tap //Remove all//). The event cache is cleared if you change the type of events available for display.
 {{ :​mobile:​timeline2.png?​nolink }} {{ :​mobile:​timeline2.png?​nolink }}
 ===== Locator ===== ===== Locator =====
-The application supports a locator functionality. ​Locator ​is used to generate links and share current ​units' ​location. ​Locator ​can be available either from the work list ('Units' ​mode) or from the 'Tracking' ​mode. To generate a link, use left swipe in the line of a corresponding unit, and tap the 'Target'. In the appeared ​menu, choose locator'​s link validity period ​(from 1 hour to week). Then choose a necessary ​action: send a location link by any messenger on your smartphone, copy it, open in a browser, etc. [[ [[user/​monitor/​locator#​viewing_on_the_map|Viewing]] is performed on locator'​s map which becomes available upon clicking on the provided link.+The application supports a locator functionality. ​The locator ​is used to generate links and share the current location ​of the unitsThe locator ​can be available either from the worklist ​(the //Units// mode) or from the //Tracking// mode. To generate a link, use left swipe in the line of a corresponding unit, and tap the //Target//. In the menu that appears, choose ​the validity period of the locator'​s link (from 1 hour to week). Then choose a required ​action: send a location link by any messenger on your smartphone, copy it, open in a browser, etc. [[ [[user/​monitor/​locator#​viewing_on_the_map|Viewing]] is performed on the locator'​s map which becomes available upon clicking on the provided link.
 {{ :​mobile:​locator.png?​nolink }} {{ :​mobile:​locator.png?​nolink }}
