Differences
Link to this comparison view
Next revision
Previous revision
mobile:mobile0:settings [04/07/2018 12:02]
tagr
mobile:mobile0:settings [08/01/2019 13:29] (current)
tagr mapl
Line 3: Line 3:
 ====== Settings ====== ====== Settings ======
-{{  :​mobile:​wm_set.png?​nolink}}To work with Wialon Mobile Client'​s ​settings, go to side menu (tap '​hamburger'​ in the app bar'​s ​top left corner or swipe the screen to the right), and choose ​'Settings'. Here you can indicate settings for a map, notifications,​ etc.+{{  :​mobile:​wm_set.png?​nolink}}To work with the settings ​of Wialon mobile client, go to side menu (tap the '​hamburger'​ in the top left corner ​of the app or swipe the screen to the right), and choose ​//Settings//. Here you can indicate ​the settings for a map, notifications,​ etc.
 **Map** **Map**
-Map layer — choose ​a map to work with (Gurtam Maps, OpenStreetMap,​ Google Roadmap, Google Satellite, Google Terrain, Google Hybrid, Mapbox Streets, Mapbox Satellite, Mapbox Satellite Streets); +  * Map layer — select ​a map to work withGurtam Maps, OpenStreetMap,​ Google Roadmap, Google Satellite, Google Terrain, Google Hybrid, Mapbox Streets, Mapbox Satellite, Mapbox Satellite Streets. Mapbox maps are available only for the Android version of the application. ​
- +  ​* ​Unit icons — enable/​disable displaying of units' icons on the map.\\
-Unit icons — enable/​disable displaying of units' icons on map;\\ +  ​* ​Unit names —  enable/​disable displaying of units' names on the map.\\
-Unit names —  enable/​disable displaying of units' names on map;\\ +  ​* ​Group units — enable/​disable displaying of a grouping icon when units are clustered ​on the map.\\
-Group units — enable/​disable displaying of a grouping icon for an accumulation of units on map;\\ +  ​* ​Geofences — enable/​disable displaying of geofences on the map.\\
-Geofences — enable/​disable displaying of geofences on map;\\ +  ​* ​Zoom buttons — enable/​disable displaying of scaling buttons on the map.
-Zoom buttons — enable/​disable displaying of scaling buttons on map.+
 **Notifications** **Notifications**
-Enable/​disable receiving of mobile notifications and choose a notifications ​ringtone. Note that to receive mobile notifications, ​it is necessary to configure their sending in Wialon. In other words, it is necessary ​to [[:​user/​notify/​notify#​how_to_create_a_notification|create a new notification]] in the corresponding panel of the monitoring system and choose ​'Send mobile notification' ​as a way of [[:​user/​notify/​action#​send_mobile_notification|notification action]].+Enable/​disable receiving of mobile notifications and choose a ringtone ​for them. Note that to receive mobile notifications, ​you should ​configure their sending in Wialon. In other words, it is required ​to [[:​user/​notify/​notify#​how_to_create_a_notification|create a new notification]] in the corresponding panel of the monitoring system and choose ​//Send mobile notification// as a way of [[:​user/​notify/​action#​send_mobile_notification|notification action]].
 **Other** **Other**
-Geofences as addresses — enable/​disable the substitution of address information ​by unit's presence in geofences.+Geofences as addresses — enable/​disable the substitution of address information ​with the information about unit's presence in geofences.
-Active screen — here you can adjust a period of time during which your screen ​to be active. The following ​variants ​are available:+Active screen — here you can adjust a period of time during which your screen ​should remain ​active. The following ​options ​are available:
-  * While charging — the screen is active ​upon device charging;+  * While charging — the screen is active ​while the device ​is charging;
   * Always — the screen is always active;   * Always — the screen is always active;
-  * Disabled — the option is not used (screen activity ​interval ​corresponds to the one chosen ​in device settings).+  * Disabled — the option is not used (the screen activity ​time corresponds to the one selected ​in the device settings).
