Differences
Link to this comparison view
mobile:mobile0:list [10/12/2018 11:00]
tagr
mobile:mobile0:list [26/03/2019 15:19] (current)
tagr [Units]
Line 8: Line 8:
 The worklist contains dynamically updated information about units. This information includes current moving state, data actuality, state beginning time, duration, and address. Note that address information can be substituted with the information about unit's presence in geofences. To do so, check the //Geofences as addresses// box in the //Other// section of Wialon mobile client'​s settings. ​ The worklist contains dynamically updated information about units. This information includes current moving state, data actuality, state beginning time, duration, and address. Note that address information can be substituted with the information about unit's presence in geofences. To do so, check the //Geofences as addresses// box in the //Other// section of Wialon mobile client'​s settings. ​
-Further, let's explore the possible options for graphical display of information:​+Further, let's explore the possible options for the graphical display of information:​
 __**Current state**__ __**Current state**__
-Wialon mobile client uses the //GPS speed// method to detect movement, regardless of the method selected on the //​[[:​cms/​units/​trip#​movement_detection|Trip Detection]]//​ tab. In order to function properly, this method should receive location and speed data. Therefore, to [[:​cms/​units/​trip#​detection_of_movement_states|detect movement states]], the minimum moving speed value should be higher than 0. Moreover, other settings specified in the Trip detector are usedin ​determining the intervals of movement.+Wialon mobile client uses the //GPS speed// method to detect movement, regardless of the method selected on the //​[[:​cms/​units/​trip#​movement_detection|Trip Detection]]//​ tab. In order to function properly, this method should receive location and speed data. Therefore, to [[:​cms/​units/​trip#​detection_of_movement_states|detect movement states]], the minimum moving speed value should be higher than 0. Moreover, other settings specified in the Trip detector are used in determining the intervals of movement.
 {{:​icons:​mstate1.png?​nolink ​ }} \\ Trip \\ \\ {{:​icons:​mstate1.png?​nolink ​ }} \\ Trip \\ \\
