Differences
Link to this comparison view
Next revision
Previous revision
mobile:mobile0:list [04/07/2018 12:02]
tagr
mobile:mobile0:list [10/12/2018 11:00] (current)
tagr
Line 2: Line 2:
 ====== Units ====== ====== Units ======
-First start of the application brings us to the 'Units' mode, or simply work list. In the work list you can monitor units' parameters, or you can switch either to the '[[Map]]' ​or '[[track|Tracking]]' ​mode from here.+After the app is launched, you get to the //Units// page with the worklist. In the worklist, ​you can monitor units' parameters, or you can switch either to the //[[Map]]// or //[[track|Tracking]]// mode from here.
 {{ :​mobile:​work_list.png?​nolink }} {{ :​mobile:​work_list.png?​nolink }}
-The work list contains dynamically updated ​unit information. This information includes current moving state, data actuality, state beginning time, duration, and address. Note that address information can be substituted ​by unit's presence in geofences. To do so, activate 'Geofences as addresses' flag in 'Other' ​section of Wialon ​Mobile Client's settings. ​+The worklist ​contains dynamically updated information ​about units. This information includes current moving state, data actuality, state beginning time, duration, and address. Note that address information can be substituted ​with the information about unit's presence in geofences. To do so, check the //Geofences as addresses// box in the //Other// section of Wialon ​mobile client's settings. ​
-Further let's explore the possible ​variants ​of graphic ​information ​presentation:+Furtherlet's explore the possible ​options for graphical display ​of information:​
 __**Current state**__ __**Current state**__
-Wialon ​Mobile Client ​uses the 'GPS speed' ​method to detect movement regardless ​to the one chosen ​on the '[[:​cms/​units/​trip#​movement_detection|Trip Detection]]' ​tab. A proper functioning of this method ​requires receiving of location ​information ​and speed. Therefore, to [[:​cms/​units/​trip#​detection_of_movement_states|detect movement states]], the minimum moving speed value should be higher than 0. Moreover, ​the other settings ​used for movement states detection are also taken into account ​in the application.+Wialon ​mobile client ​uses the //GPS speed// method to detect movementregardless ​of the method selected ​on the //[[:​cms/​units/​trip#​movement_detection|Trip Detection]]// tab. In order to function properly, ​this method ​should receive ​location and speed data. Therefore, to [[:​cms/​units/​trip#​detection_of_movement_states|detect movement states]], the minimum moving speed value should be higher than 0. Moreover, other settings ​specified ​in the Trip detector are usedin determining the intervals of movement.
 {{:​icons:​mstate1.png?​nolink ​ }} \\ Trip \\ \\ {{:​icons:​mstate1.png?​nolink ​ }} \\ Trip \\ \\
Line 23: Line 23:
 __**Ignition state**__ __**Ignition state**__
-{{:​icons:​istate.png?​nolink ​ }} \\ Ignition is on (green circle with key). Ignition off — key not shown \\ \\+{{:​icons:​istate.png?​nolink ​ }} \\ Ignition is on (green circle with key). Ignition off — the key is not shown \\ \\
-:!: //​Attention!//​\\ ​Unit's current state as well as ignition state are available only if you have 'Query messages or reports' ​right. ​+:!: //​Attention!//​\\ ​The unit's current stateas well as the ignition stateare available only if you have the //Query messages or reports// access ​right. ​
Line 38: Line 38:
 {{:​icons:​mact4.png?​nolink ​ }} the last message with coordinates was received more than a day ago\\ \\  {{:​icons:​mact4.png?​nolink ​ }} the last message with coordinates was received more than a day ago\\ \\
-On the first launch of Wialon Mobile Client the work list contains all the units available in the Monitoring panel of Wialon. However, it is more convenient if the work list contains the units you are currently interested in. To form the work list, it is necessary to move to the '​Choose units' ​menu by clicking ​the '​Eye' ​icon to the left of the dynamic search (for iOS — to the right of the dynamic ​search).+To go to the unit selection ​menu, tap the icon {{:​mobile:​eye.png?​nolink}} located next to the search ​bar.
 {{ :​mobile:​choose_units.png?​nolink }} {{ :​mobile:​choose_units.png?​nolink }}
-Units indicated by a flag in this menu are added to the work list. You can either choose all the necessary units one by one (tap it)or choose ​all the units at once (corresponding button ​in the end of the list). Use dynamic ​search ​to find a particular unit.+To add units manually, select the required ones in the list (another ​tap cancels selection) or use the //​Select ​all// button, located below the list in Android OS or to the right of the search ​bar in iOS.
-To get back to the work list after units choosingit is necessary ​to save or dismiss indicated ​changes. ​In the interface of Android ​use the green check mark icon (save changes) or red cross icon (dismiss changes) to the left of the dynamic filter. Using iOS device, tap '​Save' ​or 'Cancel' ​buttons ​situated on both sides of the menu name.+Activate the //Units from web monitoring panel// option ​to synchronize ​the application'​s worklist with the one of the [[user/​monitor/​monitor|monitoring panel]] of the Wialon web version. If this option is enabledmanual editing of the list is not possible.
 +:!: When you first log into the app, the worklist contains all the units displayed in the worklist of the monitoring panel of the Wialon web version.
 +To go back to the worklist, you must save or cancel the changes. ​To do this, use the buttons ​({{:​mobile:​check.png?​nolink}} and {{:​mobile:​close.png?​nolink}}) to the left of the search bar in Android OS or the //Save// and //Cancel// buttons ​at the top of the screen in iOS.
