Differences
Link to this comparison view
Next revision
Previous revision
limits:limits [08/02/2019 10:51]
tagr [Limitations]
limits:limits [27/06/2019 17:51] (current)
alse [Limitations] kovl
Line 19: Line 19:
   * No more than 15 million messages can be loaded by a user from one IP address within 2 minutes;   * No more than 15 million messages can be loaded by a user from one IP address within 2 minutes;
   * No more than 500 thousand messages can be imported from one IP address per minute;   * No more than 500 thousand messages can be imported from one IP address per minute;
 +  * No more than 1 message per second should be sent by a unit.
   * The maximum size of a file loaded while importing messages is 30 MB.   * The maximum size of a file loaded while importing messages is 30 MB.
Line 27: Line 28:
   * Online execution of a report takes up to 5 minutes;   * Online execution of a report takes up to 5 minutes;
   * No more than 200 executions within 5 minutes by a user from one IP address;   * No more than 200 executions within 5 minutes by a user from one IP address;
-  * The maximum number of lines of a report is 250000;+  * The maximum number of lines of a report is 400,000;
   * Report execution on jobs takes up to 10 minutes;   * Report execution on jobs takes up to 10 minutes;
   * Report execution on notifications takes up to 5 minutes;   * Report execution on notifications takes up to 5 minutes;
Line 44: Line 45:
   * No more than 3 map tracings can be processed simultaneously during one session.   * No more than 3 map tracings can be processed simultaneously during one session.
   * Within one session no more than 10 '​avl_evts'​ requests can be processed within 10 seconds.   * Within one session no more than 10 '​avl_evts'​ requests can be processed within 10 seconds.
-  * It is not possible to create more than 31744 [[sidebar/​start#​main_interface|micro objects]] of **each** type (geofences, jobs, notifications,​ drivers, trailers, passengers and report templates) in one resource. +  * It is not possible to create more than 31,​744 ​[[sidebar/​start#​main_interface|micro objects]] of **each** type (geofences, jobs, notifications,​ drivers, trailers, passengers and report templates) in one resource.
-  * The maximum number of points of a geofence [[user/​tracks/​manage|saved from a track]] cannot exceed ​10000. If the number of points of a track is more than 10000, it is saved as several geofences.  +  * The maximum number of points of a geofence [[user/​tracks/​manage|saved from a track]] cannot exceed ​10,000. If the number of points of a track is more than 10,000, it is saved as several geofences.
-  * It is possible to edit a geofence if the number of its points does not exceed 5000.  +  * It is possible to edit a geofence if the number of its points does not exceed 5000.
-  * The total number of objects (notifications,​ reports, resources, retranslators,​ routes, units, groups of units, users) created in the account cannot exceed the number of objects ​in the system available to this account. For some objects there is a reset interval: for notifications and reports — once an hour, for retranslators and routes — once a day.+  * In the top-level account, the maximum number of [[sidebar/​start#​cms_manager|macro objects]] of **each** type (resources, retranslators,​ routes, unit groups, users) cannot exceed the number of units available to this account. All limitations on the number of objects are specified in the top-level [[cms/​accounts/​dialog|account properties]].  ​
 +  * The total number of objects (notifications,​ reports, resources, retranslators,​ routes, units, groups of units, users) created in the account cannot exceed the number of units in the system available to this account. For some objects there is a reset interval: for notifications and reports — once an hour, for retranslators and routes — once a day.
   * The total number of retransmitted units in all retranslators of the account cannot exceed the number of units in the system available to this account.   * The total number of retransmitted units in all retranslators of the account cannot exceed the number of units in the system available to this account.
-  * The total number of objects (notifications,​ reports, resources, retranslators,​ routes, units, groups of units, users), as well as retransmitted units created in the subordinate account, cannot exceed the number available to the parent account.+  * The total number of objects (notifications,​ reports, resources, retranslators,​ routes, units, groups of units, users), as well as retransmitted units created in the subordinate account, cannot exceed the number ​of units available to the parent account.
   * The size of a message in an imported WLB file cannot exceed 10 MB.   * The size of a message in an imported WLB file cannot exceed 10 MB.
