Differences
Link to this comparison view
cms:users:props [21/11/2018 10:04]
tagr chdi
cms:users:props [21/11/2018 10:05] (current)
tagr chdi
Line 47: Line 47:
 **Can change settings**\\ **Can change settings**\\
-Activate this option so that the user can change the [[user/​set/​set|settings]]. If it is disabled, ​changing ​user settings and [[user/​monitor/​icons|monitoring options]] ​becomes impossible.+Activate this option so that the user can change the [[user/​set/​set|settings]]. If the option ​disabled, ​it becomes impossible to change the user settings and [[user/​monitor/​icons|monitoring options]].
 :!: To edit most of these properties, you should have the //Change flags for given user// access right. Changing password requires also the //Act as given user// access right. ​ :!: To edit most of these properties, you should have the //Change flags for given user// access right. Changing password requires also the //Act as given user// access right. ​
