Differences
Link to this comparison view
cms:units:units [12/09/2019 17:59]
alse
cms:units:units [27/01/2020 10:14] (current)
alse [Unit Properties Dialog] shol339
Line 51: Line 51:
 Unit properties dialog is displayed when you create, edit or copy a unit. It contains many tabs and fields that define different unit parameters and how the program interprets the data received from this unit.  Unit properties dialog is displayed when you create, edit or copy a unit. It contains many tabs and fields that define different unit parameters and how the program interprets the data received from this unit.
-The number of tabs can vary depending on your [[cms/​rights/​rights|access rights]] ​(the maximum number is 11)+The number of tabs can vary depending on your [[cms/​rights/​rights|access rights]]. The maximum number is 13
 {{ :​units:​tabs.png?​nolink }} {{ :​units:​tabs.png?​nolink }}
