Differences
Link to this comparison view
cms:units:general [22/08/2019 13:42]
tagr WH-1508
cms:units:general [09/09/2019 11:44] (current)
tagr
Line 16: Line 16:
 **Unique ID**\\ Enter the unique ID for the unit required to identify it by the system. Usually, it is IMEI or serial number. Some types of devices may support two unique IDs. In this case, the additional input field appears on the right. The maximum number of symbols for an ID is 100. **Unique ID**\\ Enter the unique ID for the unit required to identify it by the system. Usually, it is IMEI or serial number. Some types of devices may support two unique IDs. In this case, the additional input field appears on the right. The maximum number of symbols for an ID is 100.
-**Phone number**\\ Here enter the phone number of the unit if it has embedded SIM card. The phone number should be in the [[user/​gui/​input#​phone_numbers_and_e-mail_addresses|international format]], e.g., +15557654321. If your device supports two SIM cards, you can enter the second phone number on the right. ​+**Phone number**\\ Here enter the phone number of the unit if it has embedded SIM card. The phone number should be in the [[user/​gui/​input#​phone_numbers_and_email_addresses|international format]], e.g., +15557654321. If your device supports two SIM cards, you can enter the second phone number on the right. ​
 **Device access password**\\ ​ **Device access password**\\ ​
